Originally posted by Chris_H42
The most common way to mount them on wide angle (I ain't talking yer crappy shallow angle VR6 engines) is to make an inlet manifold which curls up and over the rocker covers.
That's the path I'm going down. makes it much easier to package up. I think the GM V6's are 54 degrees, IIRC.
I'm about to strip the second 3.0 bottom end, which is in much better condition than the 1st one. If everything measures up ok, I'll use those 6 rods, and get me some flaps!
