Mantzel, Lexmaul, dbilas or C20 XE conversion???
The corsa engine has done 40 000 miles. Any help would be grateful! Fitting the Power boxes?
Power Gains? To remove unwanted pipe work!!!
cheers
Big Block conversion is good, get high power from stock engine, and etc.. But you need remember, you increasing around more 40kg of weight only in front, the distribution of weight, handle, stability, get badder if compare a Corsa with small block engine.
Then, in my opinion, in my vision, if you looking for a street use car, for use high speed in curves, some street races, and etc..you need a good handle car.. then, keep the small block engine. If you looking for Drag Race, then, put the biggest engine you can put in your Corsa. Its my opinion.
About the price of conversion, sincerely, i don´t know about the prices there, because im from Brazil. But here in Brazil, is much more cheaper make a turbo conversion in stock engine, and you can get the same power of stock C20Let, without uprated internal parts. And remember, less 40kg...
your only talking of mounts and driveshafts being the main problem
people cant make mounts and u can get lathed down driveshafts
dont get crap driveshafts not worth it, and on the other foot, dont over pay for mounts, do a good bit of shopping round
these id say are your main things, and brakes of course, some of the more clued up lads will give u a better idea
72.7K members
