let boost
Results 1 to 19 of 19
Thread: let boost
    Mar 2002
    nottingham
    astra gsi turbo
    let boost
    which way do i adjust my actuator to get more boost as it is a little under standerd figures
    May 2002
    holytown
    insignia
    You have to turn the nut on the left side towards the actuator is self
    I WANT MY CAV TURBO BACK
    Mar 2002
    nottingham
    astra gsi turbo
    Thread Starter
    so that would shorten the bar then?
  5. Remove Advertisements
    May 2002
    holytown
    insignia
    No you will have to lenghten the rod,by moving the left nut to the left then moving the right nut to the left(to look the wastegate in place) it will pull more of the rod out the actuator.
  7. #5
    Mar 2002
    nottingham
    astra gsi turbo
    Thread Starter
    exposeing more of the bar at the battery end?
  8. #6
    May 2002
    holytown
    insignia
    thats right mate
  9. #7
    Mar 2002
    nottingham
    astra gsi turbo
    Thread Starter
    cheers mate thanks for the advice
  10. #8
    Oct 2001
    Kent
    the car in front
    Boost is like the thread exposed to the battery
    Rule of thumb: more thread, more boost
    Less thread, less boost
  11. #9
    Oct 2002
    middlesbrough
    novaturbo
    Re: let boost
    WHAT?
    www.carbon.carry-on@ntlworld.com
  12. #10
    Northeast Kent
    seemed pretty clear to me, and he has his answer.
  13. #11
    Oct 2002
    middlesbrough
    novaturbo
    That wasn't what I meant
  14. #12
    Mar 2001
    London
    Audi S4 Biturbo
    Always wondered why the LET is so sensitive to wastegate setting.
    Other eletronic boost controlled cars I've seen will have the same boost for almost any wastegate setting (within reason).
  15. #13
    Northeast Kent
    i think the only thing stopping you from winding it out to infinity is the ECU 1 bar boost limiter. I think standard boost is 0.6 flat, 0.8 overboost ? some scope for a bit of tweaking there i think, even on a standard LET.
  16. #14
    Nov 2000
    Woking, Surrey
    GTE 16v Turbo
    Remember the intercooler and fueling though.
    Contemplating lots of things
    Astra GTE Turbo - Link Now Working
  17. #15
    Mar 2002
    nottingham
    astra gsi turbo
    Thread Starter
    done it cheers lads
  18. #16
    Northeast Kent
    am i right in thinking you could wind it out so its 0.7 bar or even 0.7and a bit Just so it overboosts a smidge under 1 bar ? Increase fuel pressure slightly. gotta be worth 5-10bhp ?
  19. #17
    Luton
    when my let was standard i could have just over 0.9 bar overboost and about 0.7 constant without the ecu cutting back boost
  20. #18
    Jan 2002
    ayrshire scotland
    like a saint-9points
    ok correct me if im worng here but ive been thinking about htis for a while now.
    ok sensors tell the ecu exactly what state the engine is in. eg boost, water temp etc etc. and the ecu acts on this data to adjust timing fuelling etc to keep the engine running optimally
    now....why then do ppl "superchip" their cars to adjust the fuelling and timing to suite higher boost if the original ecu can adjust for it itslef if and when it detects it??
    am i making any sense here
    rodgerq
  21. #19
    Oct 2001
    Kent
    the car in front
    coz it refuses to operate above a certain limit.
    aftermarket chips extend the ignition and fuelling maps
