I was looking at a old Max Power DVD "The Beasts unleashed", and there was a lad called Gary Taylor from Jersey, and he had a astra running 4x4, does anybody know any more about this sort of conversion or who i could contact. Cheers!
Well if your that pig headed that you must have an astra rather than a cav and are going to put 350BHP+ in it then it is worth while to get some of that power on the road.Tim_P said:Although, 'not worth the time, money and effort' springs to mind.
Hope you were being sarcastic (again).Andy K said:Well if your that pig headed that you must have an astra rather than a cav and are going to put 350BHP+ in it then it is worth while to get some of that power on the road.
It was done by courtney.
it is slower once you pass the first 60ft
lmao lmao lmao :beer:Russ said:You obviously aint got enough power.........
Like I said, you obviously don't have enough powerOn a proper surface I don't wheelspin past 60ft
Of course the grip is increased if it stops the wheels from spinning.I swear by mine,tried driving in wet without it,massive difference.Cemesis said:Traction control on the GSi is pants, it just limits power, grip isn't increased
AgreedAndy K said:In the wet the 4x4 would be faster
I knowAndy K said:(P.S It rains alot in the UK)
I know, I hate spinning 4th gear in the wetAndy K said:"Ow I can spin in 4th gear etc etc" Not a good thing !
Theres also little point in having 4x4 after the start line where its just dead weight for the rest of the runAndy K said:There is no point having grip way past the start line if the start is so unless.
It doesn't increase grip, the engine can't increase grip, only the tyres can. It reduces power and means that grip is re-established but it over compensates alot I'm told.LEE69 said:Of course the grip is increased if it stops the wheels from spinning.I swear by mine,tried driving in wet without it,massive difference.
I think its great in the Cav, I just like to stir. The topic was originally 4x4 in an Astra which although I think sounds cool I doubt it would be worthwhile in practice, sort of defeats what the GTE is best at - scaring you Remember the fear Tim? RememberTim_P said:Mr Cemesis, never thought I would be able to say this to you, but.. don't knock it til you're tried it
But I can do thatRuss said:Look Scott, you have completely the wrong mentality;
If you can't spin the wheels in the first 3 gears on a car with a mediocre front drive chassis, then you really don't have enough power!
But here in 'not Scotland' we drive in straight lines 95% of the time, so that means the 2WD Astra is faster than the 4x4 Astra 95% of the timeRuss said:With in excess of 300bhp, only in a straight line could the front driver be quicker, and it still has to get traction first.
So you mean round a track? Yeah, the 4x4 might well win around a track.Russ said:Throw in a few corners, a wet or even slightly less than perfect grip surface (read racetrack), and a 300+bhp 4wd astra would walk all over a 300+bhp front drive astra.
Very true - turbos suck.Russ said:
Edited to add, (before the NA nutters get hold of this!) that I was really talking turbo bhp with the similar or higher torque figues as it is the surge of torque that causes the trouble.
Sorry, I appreciate that I didn't phrase it very clearly, but I actually meant that on a perfect surface the 2wd car may actually be quicker...So you mean round a track? Yeah, the 4x4 might well win around a track.
