astra fuses and oil guage on dash
i have a 1.3 astra and im sure im missing a few of the fuses in the holder in the drivers side underdash, can someone please tell me what fuses i should have? its a 1.3 astra L 1988
also how can i get the oil guage on my digi dash 2 work?
think i heard some 1 say somethin bout a nova
I dont think all the fuses are needed in lower engines of Mk2s....
Check in your car insruction book....page 83(I know the page number now...I have had to arse around with mine that many times!)
to make oil pressure feature to work you need to change your "oilddruck" with the one that can measure it and give signal to the dash.....found od gsi/gte kadetts/astras......it's located below altenator...
you need the oil pressure sender off of a gte, bolts into the rear of the oil pump in place of the standard low pressure switch.
the gte item has dual functionality, it will supply the oil pressure warning light, and the actual pressure guage.
what colour/s do the wires get hooked up 2 on the digi?
i think it is blue and blue and yellow
