changing crownwheel in gearbox
Results 1 to 25 of 25
Thread: changing crownwheel in gearbox
    Jan 2002
    Mid-Sussex
    RWD NOVA
    I am wanting to change the crownwheel in my F16 to one from an old F16cr box.
    How do I go about doing this?
    Is it simply a case of swapping the diff units?
    cheers in advance
    Jan 2002
    Mid-Sussex
    RWD NOVA
    ^bump^
    Northeast Kent
    Re: changing crownwheel in gearbox
    the final drive is made up of two parts, the diff crown wheel and the mainshaft pinion. you cannot just change the crownwheel, it will be too big or too small to match the pinion.
    I dont know if your doing this to get different final drive or just replacement due to failure, either way you need both parts.
    The crown wheel unbolts from the diff, just for reference, but you need to take the diff out to do that so straight swap the whole diff is easier.
    Mar 2001
    under the bonnet.
    Cossie pug 205
    How easy is it to change the pinion. I want to change the final drive on mine but will probably wait until I blow the gearbox.
    thanks muppet
    Now has a 4WD project. :)
    Northeast Kent
    dont know.
    Northeast Kent
    Northeast Kent
    if we take the F20. there are 2 types for FWD.
    1) 65 teeth crownwheel, 19 teeth on mainshaft pinion
    2) 71 teeth crownwheel, 20 teeth on mainshaft pinion
    1) 65 divided by 19 = 3.42 final drive
    2) 71 divided by 20 = 3.55 final drive
    Mar 2001
    under the bonnet.
    Cossie pug 205
    What models did the 3.42 come on then. I think this is the ratio I am after. Are there any 3.1's as I think that would be even better suited to my mini.
    oh and what do you mean don't know. What happened to the fountain of knowledge we expect from you.
    another question are the crown wheel and pinions the same as on the F20.
    thanks muppet
    Northeast Kent
    compared to what ?
    Mar 2001
    under the bonnet.
    Cossie pug 205
    Sorry I meant are the crown wheel and pinions the same on the F20 as the F16. doh.
    thanks muppet
    Northeast Kent
    F16 come in
    71/19 (3.73)
    71/18 (3.91)
    71/20 (3.55)
    67/16 (4.19)
    67/17 (3.94)
    67/18 (3.72)
    Northeast Kent
    the 71/20 (3.55) for F20 and F16 are the same part number, so that suggest F16/F20 sets are interchangeable.
    Mar 2001
    under the bonnet.
    Cossie pug 205
    What gearbox do the turbo diesels use and can the crown wheel and pinion be used in the F20.
    thanks muppet.
    Northeast Kent
    despite what people say, i dont think there some wonderfull beefy special diesel box thats strong enough for sherman tanks. nova/corsa TD use the F15, think mk3 astra TD used F18. mk2 astra, same.
    Mar 2001
    under the bonnet.
    Cossie pug 205
    I am not on about the strengths but just want to change my ratio's. Oh sorry for hijacking the thread as well.
    thanks muppet
    Northeast Kent
    from what i can tell mk2 diesel used 3.94 FD, mk3 TD used 3.55 or 3.74
    next idea lmao
    Jan 2002
    Stoke-on-Trent .. 0-60 5.15 Proven
    Nova LET 13.581/12.580
    I had a broken box and planed to change just the gears set.This can be done in 1/2 hour.Although the new box that i bought had 19 teeth the old one had 20 teeth.So i changed all of the box .The crown an pinion have to match regardless.If you wanted to change the final drive you would have to change the main shaft which isnt an easy task
    Mark Beeson
    If its a NOVA I might know. Ive tried/fixed everything.
    Nova 280+ bhp and a quaife straight cut gearkit + ATB and water injection and 6 pot calipers that wont fit! Now I have a power steering setup for my nova!
    I also own a Citroen Xsara VTS
    May 2002
    edinburgh
    Corsa rally car
    on the f10/13 you can change the cwp on its own but on the 15/16/20 the pinion gear is a machined part of the output shaft meaning an entire gearset would have to be changed to achieve a lower cwp, iirc.
    Hope this helps...
    MIGClub Member Johnny A's Avatar
    Aug 2001
    Oxford
    Saloon of Doom
    Was gearboxes came with the 3.42???
    I have an Gearbox off a 2.0 8v Calibra. Would that have one??
    Vauxhall Carlton estate - Z20LET, Greddy TD06-20G, 347bhp
    Billing 2011 Special needs award winner
    Jan 2002
    Mid-Sussex
    RWD NOVA
    my old gearbox was a very close box, so i'm gessing that it has the 4.19 crownwheel. My new F 16 is way too long.
    The old gearbox has a buggered 3rd gear, so i cannot use the gears.
    How do i take the pinion gear out? Does it involve swapping the output shaft?
    cheers
    Jan 2002
    The pinion gear is on the end of the main shaft.A lot of stripping down and im not sure if you need a press
    Mark Beeson
    Aug 2001
    Oxford
    Saloon of Doom
    Wanna swop boxes austin, I have an F16CR, with I am guessing around a 3.8 diff
    If u have a 3.55 I will gladly swop
    Jan 2002
    Any ideas on 1st through 5th ratios on a f20?/f28?Quaife
    Mark Beeson
    Northeast Kent
    strange as it may seem, long ratio gearboxes have a very short ratio final drive. and short ratio gearboxes have a fairly long final drive. kind of a compensator if you like.
    example
    F20 (only close ratio made), final drive 3.55
    F16 wide ratio, final drive 3.94
  26. #25
    Northeast Kent
    In an ideal world you would want a short ratio box, with short ratio final drive, perfect example is mr stickland, purchased a reconditioned F16 close, with 3.9 final drive. Hefty increase in acceleration to boot.
