Fuel Pump Relay
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 28
Thread: Fuel Pump Relay
    Apr 2002
    Brazil, São Paulo
    Astra GTE 2.0 8V Tur
    Fuel Pump Relay
    Apr 2002
    Essex - Colchester
    BMW
    no, the fuel pump relay just turns the pump on and off.
    Oct 2001
    The Netherlands
    Maybe your injectors are just to big?
    "Undercover maniac"
    Apr 2002
    Brazil, São Paulo
    ..for tips friends.
    RDS
    RDS is offline
    Jun 2001
    Plymouth
    Veccy 3.0 24v Diesel
    Originally posted by Matheus428
    no man, my injectors are perfect for 1 BAR and alcohol use. Is 1050 cc per minute of flow each injector.
    I think i found the problem, is in spark plug wires, the high temp of exaust manifold, damage the wires..i will check more correct. Thanks for tips friends.
    Mate you are off ya tree! 1050cc/min would power a evo to nigh on 800bhp! lmao
    Sir, please step away from the car
    Apr 2002
    Brazil, São Paulo
    no man..
    alcohol engine get more rich mixture than gasoline, is like 30 or 40% more..
    And in my case, i didn't work in fuel injection chip(my fuel injection is Le-Jetronic), i only make correct the mixture in high boost with injectors and rising fuel regulator.
    Northeast Kent
    maybe yuohave 800bhp matheus, thats why your tyre burn lmao
    Apr 2002
    Brazil, São Paulo
    Apr 2002
    Brazil, São Paulo
    and with this injectors, i can use more than 1 Bar(around 1.3BAR, i continuos can use this injectors), without extra injector..
    RDS
    RDS is offline
    Jun 2001
    Plymouth
    what fuel pump do you use?
    Northeast Kent
    oddball thinks your calculations have taken a bad turn, oddballs car makes 200 n/a bhp with only 253cc/min @ 3.5 BAR fuel pressure
    RDS
    RDS is offline
    Jun 2001
    Plymouth
    lmao, his car must do like 10mpg everywhere
    Apr 2002
    Brazil, São Paulo
    Yeah Oddball says correct.. for Oddballs engine 253cc is suficient, because is a gasoline engine, and N/A. The turbo engine get hotter the air(because this with intercooler, don't need so rich mixture), and you need a part of fuel, for get colder the chambers.
    Look the formule for your engine Odd(this formule is for turbo engine, then, lets suposse you using 1 BAR of pressure):
    Vi= 190(your sbd kitt power) x 5(the specific consumption for your engine/CR, fuel gasoline)/ 4/1(your possible turbo pressure) = 237,5cc/min.
    Really near of your case.
    Have more precises formules than that, that consider the temperature of air the engine sucking, and etc.. but i don't have this formule really now.
    Northeast Kent
    ok, but oddball doesnt understand. If you use alcohol fuel, surely you need less total fuel compared to straight petrol.
    alcohol is more efficient, better burn, so you need less fuel ? 753cc/min is HUUUUGE amount.
    Apr 2002
    Brazil, São Paulo
    No Oddball... .not not..not..
    Alcohol is less efficient than gasoline. Gasoline make more energy with the same amount of alcohol. Because this, alcohol need work 30 to 40% more RICH. Alcohol make more power than gasoline, because work in high CR.
    The air/fuel ratio for alcohol is 10 parts of O² for 1 part of alcohol, the gasoline is 13 parts of O² for 1 part of gasoline.
    Because this, the specific consumption of gasoline engine is less than alcohol engine.
    Northeast Kent
    aha, now oddball is understanding.
    May 2002
    North East
    MR2 Turbo
    there brazilians are too clever for my liking lmao
    Toyota MR2 - 570HP & 420Ft/Lbs
    Designed & Built BY ^Trickster^
    Tuned By Ryan.G 2 Bar Tuning
    Apr 2002
    Brazil, São Paulo
    hahahahahaahahahahahahahahahalmao
    Apr 2002
    Brazil, São Paulo
    the problem is in the distributor!!!! much oxide in conectors!!! i clean, and engine comes ok!!!!
    uhauaha.. damn..
    Northeast Kent
    matheus, do you know what this means ? someone sent this in a message on kazaa, translator web site does not make sense of it.
    ME LO DAS ASI CHATEAMOS
    Apr 2002
    Brazil, São Paulo
    uahauahauh.. its in spanish Odd.. my natural language is portuguese. Is diferent.
    But i think its mean: "me, will disturb you"..
    Northeast Kent
    yeah i knew it was spanish, the man sending the message was talking to me in english, then he asked me if i had an e-mail address, i replied yes but why, and then he reply with the above message in spanish.
    I guess it was rude words, and translator does not like them !
    Apr 2002
    Brazil, São Paulo
    hehehe.. he doesn't liked you! uhauahauahlmao
    Northeast Kent
    or more likely he DOES like me, if you get my meaning. I have blocked all further messages anyway. lmao
  26. #25
    Apr 2002
    Brazil, São Paulo
    heheheh..good way..
