hem.passagen.se/hitmeharder/koppling_0002.jpg
Made by me..
200mm diam
next thing to do..
Flywheel..
as i said..
Aiming for fast throttle response![]()
Made by me..
200mm diam
next thing to do..
Flywheel..
as i said..
my webhotel is totally fakked..
adress to copy if the pic gets lost..
what the pressure of this plate?
Looks like a standard pressure plate with the steel bodey replace with aluminium.
Guess it's the same spring tension, but a bit fragile I should think, aluminium.
Titanium would be perfect, but rather pricey.
i think, only see, you can't know the pressure.
My 1.200lb pressure plate, is the same design of stock plate too. But the stock plate have only 550lb.
Turbo kits and performance parts:
www.mvaux.com
http://www.migweb.co.uk/forums/showthread.php?p=2465872
thats impressive looking
Never get an EGG credit card they do nothing to protect you if your card is subject to Fraud!!!!!!!!!!!!!!!!!!!
do you walk round in circles matheus, now that your left leg is the size of columbia lmao
lmao
hey Oddball! i don't understand your joke!!![]()
www.mvaux.com
you don't understand what i mean Oddball. I mean about the tension of plate. The Mark CDX, tell the tension of pressure plate of Insane Sweed are the same of the stock plate, because have the same "look", "aparency". Then, i said, the "aparency" cant tell if have the same tension. Because i bought a 1.200lb tension pressure plate, and have the same aparency of stock pressure plate.
Understand me???![]()
uuhhh my damn lag!!!!
lmao lmao lmao lmao
www.mvaux.com
550lb is a lot of pressure to apply with ones foot.
must have a lot of weight behind it.
I can only manage 200lb, when standing on 1 leg.
550lb is the stock tension of stock pressure plate. Check it in GM mechanic, and you will see. Im not joking.550lb is a lot of pressure to apply with ones foot.
My actual pressure plate is 1.200lb
www.mvaux.com
lmao lmao lmao lmao
I would suggest he has used a standard plate to make that, and as the pressure is determined by the tensile strenght of the steel and it's thickness, it should be the same in a steel or aluminium body.
Aluminium will give more than steel though, if it isn't thick enough.
do you mean 1200 lb?
1.2 is a lot less than 550
and remember, the tension of clutch, don't mean the "weight" that you need put in the pedal. Because clutch, have a system for multiplicate your moviment in pedal.
www.mvaux.com
1200lbs clutch is very stiff, your left leg get lots of excersize, you walk round in circles because your left leg is bigger than the right.Originally posted by Matheus428
i think, we mean diferent units.
lb is the same of "libras", in your units, maybe is the same of psi.
1.200lb is around 80kg
550lb is around 36kg
www.mvaux.com
hehehehehehe.. now i understand..1200lbs clutch is very stiff, your left leg get lots of excersize, you walk round in circles because your left leg is bigger than the right.![]()
www.mvaux.com
Hi all..
hmm pressure.??? don´t have a clue..
But the 'spring' are from an Volvo Turbo plate that can cope with 800Nm torque with an 215mm clutch
i have reduced the diam to 200mm
but my torque will be FAR from 800Nm
at tops 400Nm when nitrous are going in.
and by the matrial..
It´s an high quality ALU called 'Alumec' good enough to make conrods with.
So i think it will cope for the rpm´s and the stress..
Cheers...
if you don´t use the newtonmeters in uk and rest of the world.
an C20xe is rated 196Nm stock. (150hp)
so 400Nm should be ~300hp
i´m aiming for 230hp at a higher rev than xe engine so the Nm will be a lower value but at a higher rev.
maybe with no nitrous I´ll have around 250Nm TOPS!!
I´m just bladdering here..
maybe you´ll understand![]()
Matheus "the Brazilian Migger" - I like that lmao lmao![]()
GSi Turbo
-= New boosting station under construction =-
hehehehehehe.. yeah!! south america can make part of this Vauxhall lovers club too!!!![]()
www.mvaux.com
Off topic i know.....was wondering what time it is in brazil right now?
Bet its not - 6 c over there!![]()
Al
