differences between phase 3 and 3.5
Page 2 of 2 FirstFirst 1 2
Results 26 to 38 of 38
Thread: differences between phase 3 and 3.5
  1. #26
    RDS
    RDS is offline
    Jun 2001
    Plymouth
    Veccy 3.0 24v Diesel
    Rob you should have been locked up years ago lmao
    Did ya get me pm about the clutch????
    Sir, please step away from the car
    Dec 2002
    north west
    nova gsi
    what are the recomended places on a nova to strengthen for a turbo engine? is it the same as a 16v or a lot more?
  4. #28
    Apr 2001
    Surrey
    A few...
    Phase 3 = 300bhp
    Phase 3.5 = 315bhp
    Both kits run the same overboost of 1.5 bar and its advised for both kits you run an uprated fuel pump. Designed for standard injectors but be sure to get them cleaned before you start.
    The ONLY difference between the two in terms of mechanical parts is phase 3 uses the standard Motronic 2.7 internal 2bar map sensor, whereas the phase 3.5 uses an aftermarket bosch 3bar map sensor and obviously slightly different mapping to cater for the change. Because the 3bar map sensor can read the boost a lot more acurately this is why phase 3.5 has better boost control and is not so eratic. This also gives you the added bonus of an extra 15bhp
  5. Remove Advertisements
    RDS
    RDS is offline
    Jun 2001
    Plymouth
    The power figures for the phase kits change more often than the weather!
  7. #30
    Nov 2000
    Woking, Surrey
    GTE 16v Turbo
    I wouldn't say that Rob, after all, it always rains here lmao
    Please guys, 15bhp is nothing, its less than 5%. Worry about traction and the thing holding itself together and suspension and brakes and everything else.
    Get a proper boost controller and you can decide on your own boost level.
    Contemplating lots of things
    Astra GTE Turbo - Link Now Working
  8. #31
    Wales
    2.0 Turbo Spider
    I thought the map sensor was just recalibrated?
    Cant see any signs of soldering afer Arno upgraded my ECU.
  9. #32
    RDS
    RDS is offline
    Jun 2001
    Plymouth
    Yes it is recalibrated come to think of it cos on Neils P4 ECU the little cover on top of the map sensor has been removed
  10. #33
    Dec 2002
    London
    R32 GTR, BMW 520D E60
    so how about skipping phase 3.5 and just getting the p4 ecu upgrade? i have just brought a set of arrow rods, so how important is the oil spray bar mod?
  11. #34
    Nov 2000
    Woking, Surrey
    GTE 16v Turbo
    The rpm is raised to 8,000rpm for Phase 4, you really need to use some uprated parts (like conrods) if you are planning on revving up there.
    It runs 1.6 bar as well which is higher than the Phase 3 overboost so the engine needs to be strong to take it, I assume the oil spray bar is for cooling.
  12. #35
    RDS
    RDS is offline
    Jun 2001
    Plymouth
    Cem you know who makes steel rods...hint ^^^^^^
  13. #36
    Nov 2000
    Woking, Surrey
    GTE 16v Turbo
    hehe
  14. #37
    Dec 2002
    London
    im just nervous about getting regal to do the machining work for the spray bars, does v tuning or rbx do the mod? and how much??
  15. #38
    RDS
    RDS is offline
    Jun 2001
    Plymouth
    use water injection will do the same thing
