Fitting a Fuel Computer to an Astra
911 views 12 replies 5 participants last post by  Cemesis
#1 ·
Anyone ever done this?
I assume the computer has some funny connector on the end that plugs into a cav ECU, anyone know how easy it would be to fit to an Astra?
#2 · (Edited)
#4 ·
#5 ·
Andy K said:
OMG ?
Oh My God
Cav 2 calibres had them and late CDi models. (aux wiring loom)
I'll have to look for one next time I go up the breakers. They must be tiny to fit in place of the clock :eek:
This has been discussed in this very forum before.
Yeah but I must have missed it.
http://www.motorscene.de/LCD-Cockpit/BC-Bilder/BC_Kadett_E/bc_kadett_e.html
There are better pictures somewhere.
You don't own a GTE Lee so don't worry ;)
Oh no not that old can of worms again :eek:
#8 ·
Yes, you can connect it. When you take off the clock you should find the blue connector right there. If not the cable and connector are just behind LCD main board. Yeah, right there. Don't mess with ECU because there is no point in it.
The real problem is to install the right one!!! That's because there are different types depending on year of the car production, tank capacity etc. The wrong one will work but it will display wrong figures.
Since you have Astra GTE 16v the right Board computer is only for the 16v model GTE. I think the calibra's will not be suitable. I'll try to find the serial or type number to post it to you.
#9 · (Edited)
Board Computers
Board Computer Part number Transmision Tank size in liters Mixure system Tyre
90242432 1236040 MT 52 Motronic 175 / 70 R 13 or 185 / 60 R 14
90241680 1236039 MT 52 Motronic 185 / 60 R 14
90242429 1236040 MT 52 L3 – Jetronic 175 / 70 R 13 or 185 / 60 R 14
90240492 1236035 AT 52 Multec LE / LU Jetronic 175 / 70 R 13 or 185 / 60 R 14
90242492 1236035 MT 52 Multec LE / LU Jetronic 175 / 65 R 14 or 185 / 60 R 14
90185131 1236035 MT 52 LE / LU Jetronic 175 / 70 R 13 or 175 / 65 R 14 or 185 / 60 R 14
90185131 1236035 AT 52 LE / LU Jetronic 175 / 70 R 13 or 175 / 65 R 14
90185130 1236033 MT 52 Carburetor 175 / 70 R 13 or 175 / 65 R 14 or 185 / 60 R 14
90185130 1236033 AT 52 Carburetor 175 / 70 R 13 or 175 / 65 R 14 or 185 / 60 R 14
#10 ·
The FC replaces the clock.
There is a green connector tied up behind the hazzard switch.
As stated you rearly need the correct one (it doesn't use the lovly program codes like the calibra/cav3).
If you buy a senator one you need to fit a divide by chip (for the speed sensor) but I would of thought a cav one should fit straight in and roughly read right.
#12 ·
The cav one you show is from a mk 3, the others are from a mk 2 cav (f-reg or earlier)
