Saab injectors, fuel pressure and borewash
Results 1 to 8 of 8
Thread: Saab injectors, fuel pressure and borewash
    Aug 2002
    Heathrow
    Cavalier 4x4
    say I run saab injectors with a P3 kit, it come supplied with a 4bar regulator? According to my calculations they`ll be pushing out 484cc? 121cc per 1 bar x 3 @3bar = 363cc, so X4 =484cc
    would I risk a borewash? may be it will over fuel at top end but thats a good thing right? as long as it dont bore wash it should be ok? or do I uses a lower FPR say a 4bar?
    Apr 2002
    Brazil, São Paulo
    Astra GTE 2.0 8V Tur
    Well, if you use a hallmeter in lambda sensor for see the mixture, you don't have risk of borewash. Begin with low pressure in line in fuel regulator pressure.
    Nov 2000
    Woking, Surrey
    GTE 16v Turbo
    Phase 3 Pressure is 4.5 bar
    I think the main reason for using them is that it was calculated that at maximum pressure when you have your foot down the Yellows would need to flow at 100% which isn't too good.
    Richie will be able to answer better.
    Contemplating lots of things
    Astra GTE Turbo - Link Now Working
  5. Remove Advertisements
    Oct 2002
    Sweden
    Astra MkI
    the LET injectors are just about the same size as saab ones..
    Go for Porsche ones instead..
    they are aviable as 530cc (?) for a human price in sweden.
    should be the same in UK..
    Kadett GT/E
    Sometimes you are the bug
    sometimes you are the windsheild
  7. #5
    Mar 2001
    London
    Audi S4 Biturbo
    Err, flow increase is not directly proportional to pressure increase.
    The formula is:
    sqrt(New pressure/Old pressure) x Old flow rate = New flow rate
  8. #6
    carlisle, cumbria
    350bhp blown up nova
    a human price? quite a big sacrifice for a set of injectors?????
    anyway, yeah whats the deal with different injectors and phase 3 kit?
    dont believe the hype
    wanted - 2 false limbs and a wheelchair
  9. #7
    Aug 2002
    Heathrow
    Cavalier 4x4
    Thread Starter
    human price?lmao
    anyway so what pressure would be ideally suited to the reds? if i use a 4bar would i risk borewash?
  10. #8
    Nov 2000
    Woking, Surrey
    GTE 16v Turbo
    Do a search for the old Red injector threads, all your answers are in there.
