c20let head sunk in between com. chambers?!
Results 1 to 8 of 8
Thread: c20let head sunk in between com. chambers?!
    Feb 2011
    Maltese Islands
    rebuilt c20let
    my c20let was burning some coolant at first it was nearly unnoticeable but by time it became like a smoke machine!. When I removed the spark plug there was a little water on piston 3 and therefore had to remove the head. Also found water in the inlet manifold port 3 and exhaust manifold. the gasket had a small visible leak near piston 3 and also found out that between all 4 combustion chambers the head had sunk in by about 1mm. the engine never overheated or anything, the head is skimmed to a point where the inlet valves are level with the head's face, had to skim it due to pitting before installing. also the block has steel rings around the bores so a standard gasket is used.
    The only thing I can think of is that the head was to thin and therefore it wasn't able to take the stress of the tightening torque
    Any ideas, the picture is of the head before fitting just marked from where it sunk in, seems that in those points there are the water ways.
    thaanks
    When It comes to motorsport its what you build not what you buy
    Sep 2004
    Nottingham / Ashbourne
    Astra VXR, Loves:Whores
    Re: c20let head sunk in between com. chambers?!
    Either way it's scrap now so just buy another head and bin that one!
    Castle Combe Action Day - Please click HERE for more information.
    Performance Vauxhall Show - Please click HERE for more information.
    Feb 2011
    Maltese Islands
    rebuilt c20let
    Quote Originally Posted by Nemesis View Post
    yes, I already have another head ready to bolt on, just wanted to know the possible cause so not to ruin another head.
    Feb 2007
    Cape Town - S.A.
    96 Kadette 200TS
    Its detonation, i have seen another car that melted pistons slightly do that, the pistons weren't that bad, the bore was perfect but the head was same like yours, head was welded up then skimmed and engine rebuilt and retuned and has been drving ever since
    Opel Corsa 20xe throttle bodies - 245bhp - 13.2 1/4 mile
    Opel Corsa 20XE Turbo - 10.7 1/4 mile @ 231km/h
    Opel 200TS - eds phase 2 - water/methanol 306bhp @ 0.9 bar boost - stock turbo
    Hertfordshire GB
    Quote Originally Posted by c20let-matt View Post
    thaanks
    If you fitted that head in that condition it was scrap before you started.
    Steve
    Pub Talk BHP And Top Speed Is All That Matters.
    Standard & uprated engine rebuild parts available, also Gripper & Quaife diffs, PM your needs.
    Feb 2011
    Maltese Islands
    rebuilt c20let
    I think it wasn't detonation as all plugs were good ..and it would sound that it's having detonation, also the pistons and bores are all fine.
    Yes, steve I was expecting a short lifetime from that head but not that short, I couldn't skim a lot from it as it was already very low.
    Hertfordshire GB
    That is the trouble that head has been skimmed too much and in your case building a high horse power engine, will have weaken the head.
    That head should not be used.
    Also if that head had been on an engine which had suffered from deternation the aluminium will be soft.
    Steve
    Feb 2011
    Maltese Islands
    rebuilt c20let
    Thanks a lot for your help, I just wanted to know the cause so not to damage another head. the one I have now is like brand new, installed new seals, emptied tappits, and ground the valves and a light skim. (least possible). Will install a new payen std gasket as I have the piano wire in the block.
    The other head failed under very low stress as the comp ratio is only 8:1 and had only 6psi of boost comp test gave about 130psi on all 4 ..just finished my running in ... from the beginning it had a little white smoke but I though it was only condensation which is good if not too much. After a few weeks it was increasing and when it was on the dyno it was smoking really bad after the 6th run.
    Thanks again hope it will be fine
