as you know i replaced my wastegate and its messed about since!
i have replaced
plugs
leads
rotor arm
dizzy cap
coil+amp
cts
removed and checked wiring loom
check every plug for voltage
fuel relay
cleaned crank sensor
checked timing
afm replaced
and it still won't start, its got fuel as it stinks and pressure is up but it can't be sparking! the eml is on with ignition so ecu has power.. it did start about 2 weeks ago but ran like ****.
need help bad as it needs to go!
