External wastegate vacuum
Results 1 to 5 of 5
Thread: External wastegate vacuum
    May 2009
    Newcastle
    Lots of Novas
    Lets say you had an external wastegate with 10psi spring and thats the amount of boost you want to run.
    Do you put a vacuum hose straight from turbo housing to the wastegate or do you still need to run some sort of boost controller (mbc)?
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Re: External wastegate vacuum
    Run the vac line only for spring rate pressure.
    "THE ROB"
    May 2009
    Newcastle
    Lots of Novas
    There is 2 vacuum nipples on the wastegate which one is used? Or do you link them up via t-piece and connect other end to turbo housing?
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    Connect to the bottom one only (closest to the manifold)
    Feb 2012
    You only need to connect the vac pipe to the bottom of the wastegate .. If you use a electronic boost controller or a ecu controlled boost solenoid then you connect to both ports on the wastegate
