Walbro pump Clet
Results 1 to 14 of 14
Thread: Walbro pump Clet
    MIGClub Member DarrenF's Avatar
    Mar 2005
    Aberdeen
    Astra Ph2 GSi C20LET
    Walbro pump Clet
    My c20let is running 303bhp @ 1 bar and now and again suffers fuel cut, currently running adjustable reg at 3.5bar standard pump and injectors.
    Just wondering if it's safe/worth fitting a walbro pump and if it's likely to stop fuel cut?
    Sep 2004
    Nottingham M1 J26
    911. Loves: Dirty sluts.
    Re: Walbro pump Clet
    You definitely want bigger injectors first
    VXR ones would be ideal and you might even be able to drop the pressure a bit (dont have the figures to hand but sounds about right)
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    Upgrade the pump and the wiring to it mate. The original ones are good but its probably fairly old if it isnt original
    Mar 2005
    Aberdeen
    Yeah was thinking Vxr injectors for better flow (old let had these)
    It's still original pump/wiring R reg ph2 Gsi!
    Jan 2010
    Hemel Hempstead
    Vectra B C20let
    If you use the SAAB injectors you won't need to raise the fuel pressure, but the only disadvantage is getting the ECU to 'learn' the new injector resistance as this is lower.
    Have you check the dizzy and rotor arm are in good condition?
    Mar 2005
    Aberdeen
    Sorry to bump this was gonna fit and uprated pump this weekend and wondering if I fit Vxr injectors (fuel pressure at 3.5 bar at moment) if I'll need to adjust anything and how do I get ecu to learn new injectors?
    Will be changing rotor arm, cap and plugs at same time.
    What's best plugs ?
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    Some people say iridium plugs are but I use Cosworth plugs and have no problems at all
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    VXR injectors flow more so you will need to lower the fuel pressure. Ideally you should have a wideband so you know when the pressure is right rather than guessing.
    Jul 2009
    Hants/Lincs
    I'm no expert but I do believe with larger injectors you can reduce fuel pressure but tbh you are probably best using a wideband to fine tune adjustment rather than rely on a best guess
    Edit: pah too slow should of refreshed page sooner ><
    Mar 2005
    Aberdeen
    Cheers for info what about Saab reds told they are better than VXR?
    Wide band is on the cards but next month... Worth leaving injectors / pump out till then?
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    Changing the pump wont effect the pressure so change that anyway. I would leave the FPR and the injectors until you have a wideband though
    Mar 2005
    Aberdeen
    Cheers what pumps best... I keep seen 044, 225, 255??
    Jul 2011
    c16xe corsa gsi
    walbro 255, thats what i got for mine.
    Mar 2011
    lutterworth
    astra mk3 gsi let
    as above
