Corsa losing coolant help
Results 1 to 10 of 10
Thread: Corsa losing coolant help
    Dec 2011
    Derbyshire
    Corsa
    Basically im loosing about half my antifreeze in just over a month, and theres mayo on the cap but not on the dipstick... Only started happening since its been cold the past couple months though it didnt happen last year.
    Its a z10xe engine on 70k mostly used for about 10miles at a time for commuting.
    My dad seems to reckon its the timing cover gasket? is this a labour intensive job?
    Any other suggestions to the problem are appreciated
    MIGWeb Moderator
    Midlands
    Nowt
    Re: Corsa loosing coolant help
    Can you see where its loosing water then?
    Dec 2011
    Derbyshire
    Corsa
    Nope no visible leaks, it's just disappearing from the header tank.
    And it's not leaking from the heater matrix either which appears to be a common fault corsa c's
    Jan 2010
    Hemel Hempstead
    Vectra B C20let
    Re: Corsa losing coolant help
    My mate had this on their 1.2, turned out to be the thermostat, got it replaced and no more using water.
    He has had a new water pump before this though, have a look at front of block with the engine running to see if there is any water from the core plugs.
    Dec 2011
    Derbyshire
    Corsa
    Thermostat seems fine, had it sniff tested aswell and that came out ok so head gasket is ruled out.
    Changed the oil and filter for the time being anyway
    Jan 2008
    Lincolnshire
    Most likely to be headgasket even though a sniff test did not pick it up
    Dec 2011
    Derbyshire
    Corsa
    Everyone on a corsa forum reckons head gasket but Ive seen a couple mechanics who all seem to think its this timing gasket as it perishes or something.
    But it gets changed when doing a head gasket anyway apparently
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    Get it sniff tested (or buy the kit and do it yourself) to be sure but if there is mayo on the oil cap its most likely the head gasket, it takes ages to end up on the dipstick
    MIGWeb Moderator
    Midlands
    Nowt
    Says he's had it done and its ok.
    Dec 2011
    Derbyshire
    Corsa
    Well I've left it for a bit and been keeping an eye on it and I seem to have stopped loosing coolant.
    But I do keep getting the mayo etc
    So I'm just going to leave it, don't fix what's not broke and all that lol
