Im putting my engine back together and got to the head gasket, i have a standard gasket and arp head studs
Im just stuck on a few things!
The gasket ive been sent is listed as BS720 for 20xe, c20xe, c20xej ( not for c20let , will it be strong enough running evo5 the 2zlets didnt fail for 4 years, i took it apart to fix turbo studs snapped off )
is it ok to use the arp studs with the standard gasket or should i go back to the 2 zlet ones i used to use on it?
Are the arp nuts just a standard socket? they look strange not a normal socket?
What torque settings should i use with the head studs?, the box has disintigrated in the garage so i have no paperwork or box for them
Thanks
