vacuum for zlet dump valve
Results 1 to 7 of 7
Thread: vacuum for zlet dump valve
    Jul 2007
    sunderland
    cav 4x4 turbo
    im thinking about fitting a dump valve on my zlet, in my zaffy gsi, where is the best place to T in for the vacuum pipe, thanks Ads
    Dec 2006
    South Africa
    Opel Corsa B c20let
    Re: vacuum for zlet dump valve
    Anywhere after the throttle body on the intake manifold.
    1997 Corsa Lite 2l16v TS Standard 1/4 mile 13.285s @ 167.7 km/h
    2007 Nissan 1400 Champ 20LET (Conversion in Progress )
    Jun 2011
    Herts
    Corsa Redtop
    if you get a dv your get instructions where to put it anyways if you not 100% sure.
    Dec 2006
    South Africa
    Opel Corsa B c20let
    most people join the T into the fuel pressure regulator pipe.
    Jul 2009
    Tyne & Wear
    Corsa SRI Z20LEH, B X14XE
    Using a dumpvalve BOV on zlet/leh you MUST T off from the fuel pressure reg, the other vacuums are solenoid controled.
    Dont link it to the standard recirc valve as the ECU opens this to control boost in lower gears. Which would cause the BOV to suck in un-metered air
    Also, make sure its twin piston valve!
    Apr 2011
    wolverhampton
    2005 zafira gsi
    You have a dv as standard on the zaffy gsi mines a 2005 and it has one !!
    Jul 2009
    Tyne & Wear
    the DV is a recirc valve>> i think he means a BOV
