Tial f38 external wastegate
Results 1 to 5 of 5
Thread: Tial f38 external wastegate
    Nov 2006
    newport
    astra coupe c20let
    Hi guys got a tial f38 mm external wastegate has anyone ever changed a diaphragm
    Mine seems to be opening when you rev it on the spot and only boosts to 8psi
    I think this is what's giving me all my driving problems
    May 2005
    Aughton
    500+bhp Tigra
    Re: Tial f38 external wastegate
    They are easy to change mate i have 2x 44mm gates on mine an have changed spring rates many times when u say it only boosts to 8psi is that with boost controll turned off as that may be your spring pressure
    Nov 2006
    newport
    astra coupe c20let
    I've plumb it in so it's straight off the turbo to the wastegate
    May 2005
    Aughton
    500+bhp Tigra
    then you have no way of controlling boost out of interest have you put it on the top or side port on the wastegate
    Nov 2006
    newport
    astra coupe c20let
    On the top I only plumb it in this way just to see if it was my boost controller
