who is running a cometic head gasket successfully
Results 1 to 22 of 22
Thread: who is running a cometic head gasket successfully
    Oct 2003
    england
    Time to get myself a headgasket for the let had my heart set on the cometic gasket but after reading a few reviews it seems they are not so good in terms of sealing,also they need implying
    Anyone had any problems and what other option of headgasket are there
    May 2005
    Aughton
    500+bhp Tigra
    Re: who is running a cometic head gasket successfully
    cometic are very good head gaskets u just need to make sure your head face is flat an your block face is flat to
    Oct 2003
    england
    I've seen quite a few reviews where both surfaces have been cleaned up very well and still leaked
    May 2005
    Aughton
    500+bhp Tigra
    Theres a big difference between a surface that has been cleaned up vey well an 1 that is perfectly flat you could clean it so its spottless but if the block or head face arnt flat then it wont mateer what headgasket or bolt/studs you put on it
    Oct 2003
    england
    I was referring to heads and blocks which have been decked and skimmed not just a polish
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    Running one with head studs and no problems at all
    Jan 2009
    Wiltshire
    Corsa TD, DC2 ITR.
    The block will need to be decked, along with head being skimmed.
    I'd just use a genuine one, with ARP stud and nut and a skimmed head.
    May 2005
    Aughton
    500+bhp Tigra
    If they are fine an the head is tightened down properly you wont have any problem i have run a 2mm cometic for 4 years now on a good power c20let with plenty of boost an has been spot on
    May 2001
    South Wales
    Nippy Cav Turbo
    Quote Originally Posted by Frisco View Post
    ran one for two years fine....now running another with arp head studs...again fine
    Oct 2003
    england
    My block was decked approx 600 miles ago head was skimmed it may need doing again if not I will leave it
    I'm running or planning on running 450 -500 bhp and I doubt the standard gasket will be upto it
    Oct 2003
    england
    Maybe its how they are being tightened down,are the gasket dimpled,
    How you guys tourqeing them down,what sequence and how much torque have you guys all had the heads skimmed and blocks decked
    Jan 2009
    Wiltshire
    Corsa TD, DC2 ITR.
    Mine went between the cylinders on my XE, it ran fine I didn't know, till I removed the head when it dropped a valve.
    May 2001
    South Wales
    Nippy Cav Turbo
    Quote Originally Posted by mirpur View Post
    standard el ring gasket wont be up to it to 300 let alone 450-500 mate lol
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    i used to run a cometic, but use a ferriday item now, bi metal, but has a silicone coating too, works very well
    Ferriday Engineering
    mike certainly knows a thing or two about big boost applications too...but head and block surface finish are everything!
    SHoNkyOpELs.de
    Oct 2003
    england
    Lol Yes I know,its just most reviews I read on the cometic they seem to all be failing
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    Torqued as per sbd instructions
    SBD_Motorsport_BLT-H1-STUD-KIT_Tightening_Method
    Oct 2003
    england
    63llb/ft seems a little low
    Also been told the gasket needs dimples added to it around the water channels
    Hertfordshire GB
    Read the instructions again.
    Steve
    Pub Talk BHP And Top Speed Is All That Matters.
    Standard & uprated engine rebuild parts available, also Gripper & Quaife diffs, PM your needs.
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    If the cometic has failed it is either poor prep, inadequate torque or wrong application altogether.
    There is another option..... available from steveboyslim
    "THE ROB"
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    Follow the instructions mate, Ive had no trouble. SBD know how to build an engine....who knew
    Oct 2003
    england
    steve final torque is 63llb/ft after going through the torque sequence, ok steve you will have to pm me your other option lol
    lee what boost you running
    Dec 2006
    South Africa
    Opel Corsa B c20let
    Why not just use the factory Zlet mls gasket.
    I'm running one on my 20let with standard headbolts.
    1997 Corsa Lite 2l16v TS Standard 1/4 mile 13.285s @ 167.7 km/h
    2007 Nissan 1400 Champ 20LET (Conversion in Progress )
