Astra MK4 Z18XE Erratic Idling
Hi all, hope someone can help prepare for a wall of text and cheers if you can help.
I have an issue with my Astra in which it has erratic idling issues (more of a chugging or a misfire not excessive jumping just twitching but you can feel it through the car, it dips rather than builds); I have previously bought a new mass airflow sensor of fleabay for cheap £20 ish sterling, I have recently replaced the thermostat and I have a small hole on the gasket between the cat and the mid section of the exhaust (soon to be fixed).
I have replaced the oil, oil filter, fuel filter, replaced the coolant coolant, checked that all pipes are securely fitted (no vacuum leaks), cleaned the throttle body, new sparks, checked the fuel injectors (that was a pain!!!) basically a good old service
What I have noticed whilst doing this, the old sparks where chard and slightly oily (a black and sticky substance so I assume oil ...durrr), a slight hole in the exhaust as previously mentioned (which I don't think is a major issue), however one weird thing the car seems to miss fire when warm.
The car runs fine when cold however when it starts to heat up / when the automatic choke goes off ?, this seems to be the problem. The Haynes manual suggests timing belt however Kwikfit (please don't torch me for this) replaced the belt / kit / water pump 15/20k ago so again I don't believe this is the cause. Another thing to note when I hold the rev's at 1k the chugging disappears ?
Another suggestion I read was the EGR valve however I believe the Z18XE doesn't have one from what my googling has suggested ?
I have read that the coil pack also is an issue, Im sure I read somewhere to try this (please correct me if I'm wrong) to take the coil pack out, turn upside down and leave the sparks in it and turn the engine over. However I didn't see any sparks but that said I don't know if the sparks were fully connected as they were just wresting in the coil pack. (certainly wasn't going to hold them in).
Edit: I forgot to mention that my earth strap is currently just "hanging" on and needs crimping and screwing in, I will be doing this today and will update accordingly
### UPDATE 1
A few more updates that might help diagnose the issue....
For a while there has been a tick near the belts of the car Im not sure if it is a kwickfit fail or what to be honest, it appeared sometime after the belt change so I don't think I could blame them. Also I thought it may be the aux tensioner and belt due to the Haynes manual recommended there looked after yearly (cant remember what it exactly said) .... I have bought a new belt and tension-er, but I put the belt under pressure and the ticking still kept on going (this may of caused the engine light) so it may be a screw in the timing belt box ?
I did get the car and spanner symbol from time to time and the good old owners manual informs me that this is an electric fault, so I assume the previous earth strap was knackered I don't think this will appear now since its been fixed.
Also the exhaust has been sealed now.
Only thing I can think is the coil pack, maf sensor or timing belt (going from haynes and other forum threads) but I cant see why it would be these due to the fact the chugging only comes into effect when it goes it warms up ?
there is an engine warning light after I did all the fixes but I didn't have my reader with me at the time, I will find that out tonight.
###UPDATE 2
Right I popped over to a mate of mines tonight who has an obd reader fault code is
P0170 - Powertrain: Fuel Trim Bank 1
Now according this this thread (below) P0170 can be running rich or lean??
P0170 Rich Exhaust C-30
P0170 Lean Exhaust C-30
http://www.astraownersclub.com/vb/sh...d.php?t=229...
This error has appeared before however I put it down to the issue being with the thermostat running to cold and thus the engine running a little rich ?
Other readings I was given on Idle this was outside and standing still for approx 2 mins at -3C outside temp,
Fuel Trim short Term: 12.5% (bank1 12.5%)
Fuel Trim Long Term 11.7 bank 1 11.7
Idle 824 RPM
Fuel System 1 status: closed loop using oxygen sensor as feedback for fuel control
Air Flow Sensor 2.73g/s
Readings on a steady rev
Fuel Trim short Term: -4.6875% (bank1 -4.6875%)
Idle 2347 RPM
Air Flow Sensor 7.9g/s
No both myself and my mate have no clue about these readings however, we thought it might give someone a better idea.
any ideas chaps ?
