How much nitrous can an 8v take?
Results 1 to 2 of 2
Thread: How much nitrous can an 8v take?
    Dec 2005
    UK
    Hi all,
    I've been toying with the idea of either fitting a turbo to my 20seh or fitting a set of bike carbs and nitrous.
    The car is only being built for the strip and as a weekend toy.
    Does anyone know what is the safest amount of nitrous this engine can take with a controller fitted as I'm unable to find any real info anywhere on the net?
    Cheers
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    Re: How much nitrous can an 8v take?
    It will take as much as you want to give it, just make sure your engine is running spot on, wouldn't want a misfire, 0.75 jets are better but 0.5 would be enough
