twin engine corsa
Results 1 to 6 of 6
Thread: twin engine corsa
    Nov 2009
    scotland
    99 Corsa turbo
    twin engine corsa
    anybody thought about fitting the complete front end of a corsa sutably trimed up and braketed into the back of an other corsa to make 4 wheel drive ,that way you would have perfect factory geometry please comment also has anybody fitted an auto box with an xe engine into the front of a corsa ,as this would be the pracical set up in back to avoid gear likage hassels
    john thanks
    Nov 2007
    nottingham
    astra H 1.9 td, corsa 4x4
    Re: twin engine corsa
    I take it you mean the engine as well? theres one being done mate...http://www.migweb.co.uk/forums/proje...ated-post.html
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Been done plenty.....one of the better ones is Beardy's. Its in the resto section should you feel the need to trawl through it.
    Perfect geometry Its far from perfect and matters made much worse by transfering that geometry into the back
    Tbh twin engines tend to drive like 3 legged donkeys and get mullered on qtr and round the track by a half decent mono motor.
    Great fun as a project though
    "THE ROB"
    Nov 2009
    scotland
    99 Corsa turbo
    I have seen this i mean using the complete front end inner wings front crossmember cut down bulkhead etc just wheeled into place braketed and bolted in making sure it is perfectly lined up
    Nov 2007
    nottingham
    Too much work mate and i cant really see any advantages of doing it that way tbh
    Oldham, Lancs
    3.0V6 Corsa With NOS
    Funny thing is i agree with everything RS1 says and i am building one
    I think alot fail because of the way they are built as 99% are done in the way you are saying, which is the reason which i spaced framed it all and built in all over adjustment so i can make small or large changes to the suspension setup.
    Plus if mine fails which i really hope it dosent as i would says mines one of the highest spec built, i will remove the front engine and just play with RWD
    The bottom line with everything if a jobs worth doing its worth doing right.
