+1mm valves on an let advantage or disadvantage
Results 1 to 7 of 7
Thread: +1mm valves on an let advantage or disadvantage
    Oct 2003
    england
    is it worth the upgrade of +1mm valves on an let, what are the gains or disadvantages,
    Oct 2010
    county durham
    astra coupe turbo
    Re: +1mm valves on an let advantage or disadvantage
    no dissadvantages really but personally unless wanting above the 450bhp mark i would not bother as gains would only be about 3% even in a race spec head. these heads flow very well anyway
    468BHP AND 444TORQUE (REGAL TUNED AND BUILT SLEEPER)
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Disadvantages are that it injured my wallet
    Will the +1's be accompanied by cams? doubles? solids? Need the full picture.
    "THE ROB"
    Oct 2010
    county durham
    astra coupe turbo
    oh i know its not cheap my build has cost thosands but when im driving with a 420ish bhp monster ill be very happy :-)
    Oct 2003
    england
    rs1 the head is ported polished, bronze guides cut down on the exhaust side,double valve springs, titanium caps, i dont know if the spring seats are uprated items or normal cant seem to find any pics of the double valve spring seats, will be running hydraulic new gm lifters with xe cams at the moment.
    maybe solids and hotter cams later, i did ask to have a bit taken out of the head so if i do go for hotter cams the lobes dont touch but been told this cant be done until the cams are present as he doesnt know how much material to remove
    The valves taken out were rec 458 wasted stem 33mm they have only done 400 miles and standard on the other side but i want to aim for around 500bhp
    Oct 2003
    england
    Where would money be best spent on the +1mm valves or solid lifters with hot cams and run the standard sodium valves with rec 458 wasted stem on the inlet, head already ported and polished with double springs and titanium caps
    Hertfordshire GB
    Quote Originally Posted by coupe-sleeper View Post
    Who ever told you they will account for a 3% increase is talking rubbish.
    You cannot put a percentage gain on any indvidual modification, it is the sum total of the parts which give you the overall power figure.
    Doing only part of the work will affect the power delivery for the worse.
    Steve
    Pub Talk BHP And Top Speed Is All That Matters.
    Standard & uprated engine rebuild parts available, also Gripper & Quaife diffs, PM your needs.
