ive managed to find a bit of info on these cams
z18xe vaux part no :90512899 inlet 92219553 exhuast
Duration Inlet: 206 deg (not sure)
Duration Exhaust: 210 deg (not sure)
Valve Lift Inlet: 8,50mm
Valve Lift Exhaust: 8,00mm
x20xev
252 duration 8.5 mm lift
can anyone comfirm this and turn it in to english for me is the x20xev cams going to be better preformance ???
its just i have both bits sat here the z18 in the car and x20exv cams sat here was going to have a play with them didnt see the point if there wouldnt be much gain. Kent cams have this 1:
