nimonic and 214 stainless steel valves
Results 1 to 10 of 10
Thread: nimonic and 214 stainless steel valves
    Oct 2003
    england
    What's the advantage of nimonic valves in an let exhaust side in comparison to 214 stainless steel valves ,power trying to achieve around 500bhp
    Also how good are sterile seated valves in comparison to nimonic and 214 stainless
    Oct 2003
    Cirencester, Glos
    GTE 16v Turbo
    Re: nimonic and 214 stainless steel valves
    Nimonic - Wikipedia, the free encyclopedia
    Wiki can be unreliable but it's a source at least..............................
    Oct 2003
    england
    Is it a must in a high powered let how much better are they than stainless,what temps can the exhaust gases on an let get to as stainless I think can handle around 750 degrees max
    MIGClub Member bigron1988's Avatar
    Aug 2009
    southport
    570.6bhp corsa @1.9bar
    Jut having some of these fitted to my let now, as I got told that Stainless won't last with the heat
    carbon clad corsa gsi ,c20let big power build thread
    http://www.migweb.co.uk/forums/proje...lots-pics.html
    Oct 2003
    england
    What about stellite will they take the heat
    Sep 2008
    Auckland, New Zealan
    Chevette XE, Calibra
    Someone correct me if I'm wrong, but as I understand it, Stellite was used as a facing for valves to reduce face wear when lubricating lead compounds were removed from fuel. It's also used as a seat material due to it's hardness and durability.
    In the head, the seat has little by way of combustion heat to endure and is well cooled by the surrounding head material whereas the valve head (both the front and the rear of the valve head) have to withstand very high temperatures and effectively run red hot with the only cooling effectively being through the seat and the guide.
    The very high head temperature of the exhaust valve, and the associated expansion, may cause the two seat faces to move relative to each other, possibly rendering a careful lap in redundant - I don't recall a definitive answer, either way.
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Nimonic can handle the abuse in terms of heat
    How hot are you running though? If you dont need them its just something on the spec list and a wad of cash out your pocket
    ALS use is a likly scenario to build excess heat....although imo you'd be on the wrong valves using nimonic with antilag that is of any use.
    Vmax events perhaps? Where else do you get chance to holding a 500hp LET WOT for more than..... 15 seconds or so?
    "THE ROB"
    Oct 2003
    england
    I dont know how hot im running and your right about a wad of cash if i can get away with stainless valves id use them but dont want to keep taking the head off to do things
    how would you build enough heat to damage a stainless valve, how long would you need to be on full throttle to cause heat damage to a valve
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    How long is a piece of string?
    Pretty sure steveboyslim can give you a good idea of differance between the steel and n80 in terms of the.....integrity at x temp. I know he can get his hands on both should you require them
    Cant say ive heard of many failures of steels but it totally application dependent. If your not doing any testing then its best to air on the side of caution and 'over spec' your build imo.
    "THE ROB"
    Oct 2003
    england
    the valves i took out were rec 458 wasted stem 33mm and standard on the other side
