hi all,
i have a vectra 2.2 dti sri 2001 51 reg (y22dtr) i have recently fitted a second hand diesel pump 0470504016 as mine had a po1631 trouble code, started the car the after fitting new pump, fitted new battery, cleaned inlet manifold due to a lot of gunk in there and also had a new egr valve in august 2011, the car now runs and revs round to the limiter fine, yet if i leave it to idle for 30 seconds or so the engine light come on and goes in to limp mode, once car is stopped then restarted its fine as long as it's not left idling for 30 seconds or so, its been sat on my drive now for around 6 weeks doing my head in witht his fault, haven't taken it out on the road as it has no tax or mot, pretty pointless doing tax n mot if i haven't got it running fine yet, anyone had similair problems or could shed some light on this problem?? any common things i should be checking, i'm hoping it's not the pump again otherwise it'll be going and i'll be getting something smaller and quicker!!! HELP!!!
