pot type flywheel clutch fitting
Results 1 to 2 of 2
Thread: pot type flywheel clutch fitting
    Oct 2001
    Inverurie
    s3 + nearly a mk3 gsi LET
    is it possible to fit the pressure plate the wrong way round on a c20xe/let pot type flywheel f20 box/clutch?
    just wondered really. did some google and mig searches on it to read up for future clutch issues (my mechanical skills / luck means i will have more problems)
    clutch is brand new luk 3 piece standard jobby.
    there appeared to be a gap if i fitted the friction plate one way on the pressure plate then nothing the other way round (couldnt see any markings / didnt read em) so i fitted it the way it went togethor smoothly and popped the gearbox on no probs at all.
    what is the correct way with pics if anyone has? Haynes is very vague on this.
    Wanted: mk3 astra gsi diamond black bits + let bits dave_hay5@hotmail.com
    MIGClub Member DarrenF's Avatar
    Mar 2005
    Aberdeen
    Astra Ph2 GSi C20LET
    Re: pot type flywheel clutch fitting
    Yes, they only go one way. Should say on plate gearbox/flywheel side.
