I WANT TO USE ONLY FRONT BSC, AND ONLY AFTERMARKET BLOW so I DESIGNED A DIAGRAM LIKE THIS:
SO TURBO FEED FOR BSC, BSC Connected with Actuator, and the third pipe from BSC should be going back to AIR INTAKE PIPE Before turbo but i connected it (trough V.BOX ) with INLET MANIFOLD line to increase pressure for FPR AND BLOW...IN THIS WAY BSC have enough vacuum, and FPR and BLOW too...
I could put away this vacuum box but i think it's better this way???
IS IT GOING TO WORK??? ANYONE TRIED ONLY FRONT BSC WITHOUT REAR???
Thanks!
