so, newer fuel systems? no return?
how does the feed only fuel system on the newer vauxhalls work?
what we know... older vauxhalls have pump in/at the tank, fuel feed forward to the rail, keeps pumping untill the fuel pressure in the rail exceeds the fpr setting, and the rail overflows excess back down the return to the tank.
so some newer engines only seem to have a feed? does the pump just have a pressure regulator built into it tank end? can the pump only pump so much pressure?
reason for question is i want to fit a engine with a feed and return (c20xe) into a vaux which only has a feed.....
