Hi everyone, I have an Omega 2.5 V6 manual, and have been struggling for a couple of months with a misfire. To cut a very long story short i have replaced, Spark plugs, HT leads and coil pack and it's still the same. I have checked for fault codes and there is just 21, for throttle position sensor. It seems to be mis-firing on 3 and 6.
Now the only thing left i think it could possibly be is ECU or broken/dodgy wire from ECU. I have a very small amount of electrical knowledge and a multimeter, but i looked and the wiring diagram in the Haynes manual and it's melting my brain a little bit! I know there are 4 wires going to the coil and 1 is live, I guess the other 3 are pulses which tell each set of 2 leads/plugs when to spark. I have found 3 of the wires (1 live and 2 others) but cand find the grey/black trace. The live seems to be fine but does anyone know what sort of voltage should be going through the others and if it is a pulse?
Or If it might even be something else i am missing?
Any help will be much appreciated i am running out of ideas now!
I can post pic of wiring diagram if that would help, Thanks, Dan
