c20let code 13,22
right guys im having problems with my c20let its not running right at all
ive changed the following: lambda sensor coolant temp sensor engine loom ecu adjustable FPR
AND STILL I GOT CODE 13 AND 26
what can it be ive had this thing for about 4 months and aint be able to use it i just want to get it on the road
please help me im going insane
Re: c20let code 13,22
Anyone got any ideas
Also my car does not run when I disconnect the AFM
26 is to do with injector 2, high voltage?
it maybe that injector 2 isnt clipped in the properly giving it a dodgy connection and this code, push down on the plastic caseing that runs above it, i had a situation the same on my xe, which was the result of this.
13 will come up with any code that is wrong. work on getting 26 fixed, reset the ecu by doing turning the ignition on/off 25 times or dc the battery for several minutes and try again.
Sorry guys it's code 22 not 26
Code 22 tps low voltage
have you checked all connectors that go into the tps or replaced the tps?
I've changed the loom ecu and I've checked the resistances in the sensor and all looked fine but it's bringing the code up and won't accelerate after 2500 when trying to drive it up the road but on stand still it will rev right up with no problems
wrong tps - last year i fitted a new throttle body with tps to my redtop done the samething put the old set up back on worked ok
dont know what the difference is between the adjustable tps and non adjustable
Aw right I've got a 3 pins on there non adjustable ain't the adjustable ones got more pins?
no same same amout of pins from what i can remember
it should rev if you unplug it
check the part number on it if you can
let ends in 004
xe ends in 001
Ok ill have to have a look and see what it ends in
