setting up c20let
Results 1 to 11 of 11
Thread: setting up c20let
    Nov 2009
    Newcastle
    setting up c20let
    Long story but hope someone can help out here Bought a let in a corsa to use the engine in my corsa, the donor car was great but seemed to over fuel and get hot (sat near half way and some times near the 100) with normal driving, now that its in my corsa I have fitted a bigger rad and fitted standard yellows back in but the temp went straight to half way so I knocked it off thinking it must be under fueling I fitted a gauge on the rail and the fuel pressure was about 2bar ish so adjusted the cossie fpr but the max it would go to is just under 3bar. Have it missed something out or done something wrong?
    Heres the spec
    xe inlet cam at
    cossie fpr
    eds phase 2 chip set (running 15psi of boost)
    3'' tophat with 2.5'' boost pipes
    2.5'' stainless exhaust system
    The injectors it had in were blue heres the spec
    Delphi / Lucas
    42 lb / hr. '009' Disc Injectors
    Part Number Delphi 01D030B (Lucas old 5208009, Lucas New 621031)
    Static Flow Rate: 42.29 lb/hr @ 43.5PSI (300kPa) or 320gm/min
    Dynamic Flow Rate: 9.96 gm/pulse - 2.5ms pulse width and 10ms repetition rate
    Coil Resistance: 15.9 Ohms / High Impedance / High-Z (No ECM driver modifications required)
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    Re: setting up c20let
    Did you set the fuel pressure with the vacuum hose on or off? If on your fuel pressure will be over 4 bar, set the fuel pressure to 3 with it disconnected
    Nov 2009
    Newcastle
    Set it with vacuum on?
    Apr 2007
    Bradford
    Vectra B C20LET :)
    Take the vaccum off and set the fuel pressure again to 3.5 bar on yellow injectors for phase 2.
    Feb 2012
    Fife
    Cavalier V6
    have you checked the usual reasons an engine overheats? e.g. temp sensor, fan, head problem? maybe its not related to the fueling.
    Nov 2009
    Newcastle
    Temp sensor looks new but might replace it to be safe and engine ran mint in the old shell apart from temp sitting near 100.
    When i ran it the other day the gauge read 95 but the rad was just warm like i said has a brandnew thermostat as well
    Jan 2008
    dublin ireland
    CALIBRA16v turbo
    Try a new sensor in the rad I had mIne look like it was over heatin. But the rad was just a little warm and it shows it was in the red in the car put new one in and no problems since. But the sensor and rad ran fine from the donor car sO don't no y I didn't work In the new shell tho
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    They do tend to get a bit warm anyway, not sure 95-100 is anything to worry about tbh. Is the fan coming in/out ok?
    Fuel wise i would be a bit concerned that you cn only get 3 bar max. Wit vac off its only going to rise 0.5 or so which may be a concern once its on boost if you cant get the base figure correct.
    What fuel pump you using?
    "THE ROB"
    Nov 2009
    Newcastle
    Standard sport pump
    Apr 2010
    southport
    2008 civic diesel
    Quote Originally Posted by Crana View Post
    Heres the spec
    xe inlet cam at
    cossie fpr
    Delphi / Lucas
    assuming you have a standard stat in your running temps are fine the stat opens at 93deg, and by the time the fan has cooled the coolent and circulated it round its usually just under 100 on the dash, as above if the fan comes in you wont have anything to worry about.
    Nov 2009
    Newcastle
    Looks like my fpr is fooked, tried to wind it off abit and the screw is threaded no wonder the fuel pressure wouldnt change been looking on ebay and theres a few anyone bought one off there? Going to try a 3.0bar standard reg tomorrow and see if things improve cheers
