c20xe spluttering on low rpm help needed
Results 1 to 8 of 8
Thread: c20xe spluttering on low rpm help needed
    Dec 2009
    birmingham
    astra 1.8 gsi/2.0xe
    as tittle realie i have got a c20xe in my mk3 astra and yesterday on the way to work when eccelorating to overtake a lorry on the motorway the power just died and the car started jurking so backed of the power and applied it again and was fine 5 minutes later it started doing it again so had to turn around and head home joining back onto the motorway it done the same thing so gave it some hard ecceloration and it cleared and got back sound. after sitting scratching my head for an hour after getting back i went to investigate what it could be. i tested compression was equal and good across all 4 checked plugs all the right colour so connected a strobe to check leads they are also ok. what could this be? i think it is overfueling as does smell rich every now and then and don't do it when i put my foot down only when on lower rpm as if it flooding the engine what could this be lamber sensor? no eml on but does work as comes on with ignition. any help welcome and sorry for the essay
    Mar 2011
    birmingham
    corsa
    Re: c20xe spluttering on low rpm help needed
    Injectors leaking? Seals good on them?
    Dec 2009
    birmingham
    astra 1.8 gsi/2.0xe
    injectors are sound mate its as if its getting too much fuel as when i boot it it clears up and runs sound it only happens when going slow as if engine is getting flooded. its only started since tightening a leak i had from the valve on the fuel rail i'm just wondering if with the slight leak i had before was stopping this from happening and now its got full pressure its over fueling
    Mar 2011
    birmingham
    corsa
    What colour injecters you running and what fpr?
    Dec 2009
    birmingham
    astra 1.8 gsi/2.0xe
    standard fuel reg and standard blues
    Dec 2009
    birmingham
    astra 1.8 gsi/2.0xe
    anyone
    MIGWeb Moderator
    Midlands
    Nowt
    Its only been a few hours since you added some more information.
    Please give it some time for a reply.
    Aug 2007
    brighton
    C20LET 5dr corsa
    im having this problem with my let!! im sure last time it was my lambda, try un plugging it.
    Roll on LET power....
