Bad Miss when driving on X16XEL
Results 1 to 6 of 6
Thread: Bad Miss when driving on X16XEL
    Jan 2012
    driving along and the car started spluttering and backfiring....Fault code P0351 for Ignition coil A high signal....replaced the coil still the same.... any ideas
    Jun 2008
    Stamford, Lincs
    C16SE + X16XEL Mk3 Astra
    Re: Bad Miss when driving on X16XEL
    Check the wiring and clean up all the earths and see if that improves it.
    C16SE • Cruise Control • GSi Trip Computer • 4-2-1 Manifold • OEM+ Interior • Apex -40mm Suspension
    MIGClub Member Turbostevo's Avatar
    Jan 2011
    Chesterfield, derbyshire
    Saabastra/E36328/bora/147
    HT lead order MUST be wrong....
    Jan 2012
    not a miss but more like of a cylinder
    Jan 2011
    Does it sound like it runs on 3? If so start at the bottom, as in change the plugs, then leads, coil pack.
    Disregard my previous comment.
    Dom
    Dom is offline
    MIGClub Member Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    These engines can be prone to a number of issues. As above - try leads / plugs etc first.
    They also suffer from slipped bottom crankshaft pulleys (the one for the aux belt not the timing belt) when they aren't located on the woodruff key properly - this throws out the reading to the crank sensor.
    Other faults could be sticky valves - a compression test would confirm this.
