Fuel injector o rings?
Results 1 to 10 of 10
Thread: Fuel injector o rings?
    Nov 2009
    cheshunt, north london
    like its stolen, nova
    Can you buy the o rings on the fuel injectors or only the whole injector? mine has a break in the o ring and it's making it leak fuel so need to sort this ASAP, it's a late type c20xe if that matters
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Re: Fuel injector o rings?
    Can get them seperate
    "THE ROB"
    Nov 2009
    Nice one, no need to try and buy 1 injector then
    Nov 2009
    Just to be sure, the bit I'm on about is the rubber o ring at the top of injector, where it goes into the fuel rail
    May 2006
    South Wales
    subaru impreza/mk3 astra
    yep, you can buy just the rubber o rings on their own. i bought some a few years back from vaux.
    Nov 2009
    Ok thanks, will be getting some tomorrow
    Nov 2009
    Right after about 2 hours of going round asking about them iv still not got them, even vauxhalls wasn't much help, last place I went gave me some sealant that's not affected by fuel, have put than on and it seems to have sorted it, if it comes to it could I swap the top and bottom o ring round? And would that cause a problem if the bottom one leaks? It's only a small bit that's broke off but enough to let it leak
    Jul 2009
    Hants/Lincs
    Nov 2009
    thanks for the link mate, would it be the bottom ones or top tho that i need for the top of the injectors? that way i can just tell vauxhall the part number
    Jan 2010
    Hemel Hempstead
    Vectra B C20let
    I got some from the bay ages ago and never had a problem you need the Bosch 0280 ones.
    VAUXHALL INJECTOR REBUILD KIT SEALS FILTERS 4 CYL BOSCH | eBay
