Turbo help.
Results 1 to 5 of 5
Thread: Turbo help.
    Nov 2010
    Turbo help.
    I'm needing to get a different turbo to fit my let. The reason I need to change the kkk is it sticks out to far from the block and I'm very restricted for space. I would like about 250bhp and I would like to keep the standard ecu. Anyone got any ideas?
    Baz
    Dec 2006
    South Africa
    Opel Corsa B c20let
    Re: Turbo help.
    In what are you fitting it that you don't have space ?
    1997 Corsa Lite 2l16v TS Standard 1/4 mile 13.285s @ 167.7 km/h
    2007 Nissan 1400 Champ 20LET (Conversion in Progress )
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Re: Turbo help.
    The k16 is fairly compact to be fair, is it in a mini or something?
    "THE ROB"
    Jan 2009
    ipswich
    mk2 astra turbo
    Re: Turbo help.
    If your restricted for space on a k16 then I would say fab up a custom mani to move the turbo over the gearbox
    He who laughs last, thinks slowest.
    Nov 2010
    Re: Turbo help.
    Yea it's going into a mini with an extended front. I've seen some t05 conversions that are really tight to the block or even sat over the gearbox. But I've read on here somewhere that there has been some running issues with the td05 and standard ecu
