Converting a cavalier from c18nz to c20xe (redtop).
Results 1 to 10 of 10
Thread: Converting a cavalier from c18nz to c20xe (redtop).
    Nov 2010
    Bury St Edmunds
    Vectra 1.8 16v
    Due to a cooling issue with my c18nz in the cavalier im thinking about getting a redtop put in there.
    Whats needed for the conversion , could someone please put me a list of whats needed to do/complete the conversion?
    thanks mike.
    Nov 2010
    Bury St Edmunds
    Vectra 1.8 16v
    Re: Converting a cavalier from c18nz to c20xe (redtop).
    uppppppp
    MIGWeb Moderator
    Midlands
    Nowt
    MK3 Cav?
    MK2 Cav?
    Sep 2009
    Isle of lewis
    Cavalier turbo, mk2 golf
    Mk3 cav
    you need engine. engine loom. ecu. id get a gearbox also. f20 be the best. mk3 cav multi point inj fuel pump. Depending on what xe you get early or late there will be other bits like coil for early and ign amp for late
    throttle cable. 2l brakes . few more bits and bobs
    tbh mate your better finding a smashed or rotton vaux with the engine in already then you kno everythings there.
    Jan 2005
    Cumbria
    Cav GSi & Cav Turbo
    Best to buy one you can hear running,
    but there is few on eBay ..
    c20xe engine | eBay
    redtop engine | eBay
    But as stated above, you need - Engine / manifold, loom ,ECU , F20 Gearbox , ( Drive shafts should be ok?) maybe need to alter fuel pipes the sender and return.
    Engine / gearbox mounts should be Ok.
    Owns: Cavalier GSi & Cavalier Turbo
    Shafts and brakes will be the same.
    Nov 2010
    Bury St Edmunds
    Vectra 1.8 16v
    cheers guys at least i have a rough idea
    Two things tho:
    1. Aill i need to swap the dash looms or will it be a case of plug and play ?
    2. Are the 1.8 brakes the same at whats fitted to the sri/gsi with a c20xe as my 1.8 ones are ****ing ****. lol
    cheers
    Joy
    Joy is offline
    Sep 2001
    Devon
    2WD Cav Turbo
    1. You should just need engine loom, I converted my c18nz to an XE a long time back & only changed the underbonnet loom.
    2. 1.8`s have different front brakes, they are the same diameter but narrower with smaller calipers - it`d be worth fitting the 2.0 setup (its a stright swap).
    3.0 V6 Mk3 Cav - Saab B308I, F28, Speedlines, Wilwoods
    Cav 16v Turbo - T34, water inj, 26psi, F28, LSD, Speedlines
    04 Monaro 5.7 CV8 - Pedders Suspension, Wortec Catback
    Nov 2010
    Bury St Edmunds
    Vectra 1.8 16v
    Quote Originally Posted by Joy View Post
    2. 1.8`s have different front btakes, they are the same diameter but narrower with smaller calipers - it`d be worth fitting the 2.0 setup (its a stright swap).
    did u have to swap the fuel lines for mpi ones and add a MPI fuel pump fella ???
    Joy
    Joy is offline
    Sep 2001
    Devon
    2WD Cav Turbo
    Yep, you`ll need to swap fuel lines - only from under the bulkhead to the engine & you`ll need the mpi pump.
