coscast head valve steam seals?
Results 1 to 25 of 25
Thread: coscast head valve steam seals?
    Sep 2008
    glasgow
    calibra turbo 93
    Any one help need to were a can get valve steam seals for the costcast head ?
    MIGWeb Moderator
    Midlands
    Nowt
    Re: costcast head valve steam seals?
    Vauxhall?
    Nov 2005
    chester/n.wales
    evo 6 gsr
    stem seals are the same for coscast or gm matey
    phil nichols - Engine building and Cylinder head work. stock - performance. - can now supply gaskets, water pumps, cambelt kits, oil pumps, uprated bearings, bolts, rings, pistons. PM FOR INFO
    Sep 2008
    glasgow
    calibra turbo 93
    Re: coscast head valve steam seals?
    Tryed vauxhall they only list one set and that will be the ones for the gm head av tryed the gm ones and they are 2 big?
    Dec 2006
    South Africa
    Opel Corsa B c20let
    Quote Originally Posted by tamdoc View Post
    Then it was the wrong ones.
    The 16v head takes the same as the coscast head.
    1997 Corsa Lite 2l16v TS Standard 1/4 mile 13.285s @ 167.7 km/h
    2007 Nissan 1400 Champ 20LET (Conversion in Progress )
    Jan 2005
    Cumbria
    Cav GSi & Cav Turbo
    I bet they'll have give you valve stem seal for the Ecotec.
    here you go..
    VAUXHALL REDTOP C20XE C20LET VALVE STEM SEALS x16 | eBay
    Owns: Cavalier GSi & Cavalier Turbo
    Sep 2008
    Auckland, New Zealan
    Chevette XE, Calibra
    Two different sized guides, so two different sized stem seals - a 13mm which, IIRC, is the early one and the 11mm which is the later and german spec guide.
    if the stem seal is too big to sit on the guide, get the later type and if the other way round, get the early 13mm seal. Valves are the same, 7mm, diameter.
    Oct 2003
    Cirencester, Glos
    GTE 16v Turbo
    Autosprint worth a go. As are Autovaux.
    Sep 2008
    glasgow
    calibra turbo 93
    Cheers yea it will b the 11mm ones a wil need then lol but vauxhall only list the one size but they dont have a clue a told them it was for a costcast head and he didnt even know wot that was lol
    MIGWeb Moderator
    Midlands
    Nowt
    Did you say costcast or coscast?
    Sep 2008
    glasgow
    calibra turbo 93
    Ha yea a said coscast head its just the way ma phn puts it in lol
    Apr 2010
    southport
    2008 civic diesel
    Quote Originally Posted by Gordo View Post
    the bit where valve stem seal sits is the same size on both buddy....
    Sep 2008
    glasgow
    calibra turbo 93
    Quote Originally Posted by mikesmith181 View Post
    As gordo said there two sizes mate a am a mechanic the standerd ones are to big and dont fit on the guide a take it there alot of people dont know that then.
    Sep 2008
    If you're still stuck, give SBD a call (or QED, etc), I've found them good to deal with and they have both sizes.
    Tel: 0208 391 0121
    may be a bit more than other sources, but if they save the hassle, well worth it, IMO.
    Nov 2005
    chester/n.wales
    evo 6 gsr
    someone ****ed something up as stem seals are the same whether coscast or gm, the early coscasts are 13mm od where it fits into the casting, then machined for 11mm where the valve stem sits. so a set of 20xe stem seals will fit either guide. there is no way vauxhall would make oddballs stem seals, spring platforms for early coscast heads as it would cost too much to do.
    Jan 2005
    Cumbria
    Cav GSi & Cav Turbo
    I thought, it was Cosworth that made the Coscast head.
    Oct 2003
    Cirencester, Glos
    GTE 16v Turbo
    They did the castings.............................
    Sep 2008
    glasgow
    calibra turbo 93
    Quote Originally Posted by philip2 View Post
    Wel av got 3 coscast heads here that are needing the smaller valve steam seals as a have loads of standerd seals about and they dont fit lol
    Sep 2008
    glasgow
    calibra turbo 93
    Tel: 0208 391 0121
    cheers mate
    Apr 2010
    southport
    2008 civic diesel
    I have both size valve guides here buddy and they are exactly the same size stem seal for both, a pic can be supplied if need be.....
    Apr 2010
    southport
    2008 civic diesel
    Left is standard gm, middle bronze gm replacement, right coscast bronze replacement.
    I too am a mechanic buddy and i've stripped a fair few xe/let heads........
    Sep 2008
    glasgow
    calibra turbo 93
    av built loads of xe's and lets av got loads the now av got 6 the now lol the head is in the engineers the now even he said there to differnt size of seals for the coscast head the standerd gm ones dont fit there too big for the guide and its the original guides that are in it :-D
    Apr 2010
    southport
    2008 civic diesel
    LMFAO maybe it's a ford head you have then buddy as vauxhall have only ever produced one size stem seal for gm and coscast heads
    Jan 2008
    dublin ireland
    CALIBRA16v turbo
    Not lookin to get in the middle of if there is 2 sizes. but I built a coscast head last year had dubble springs in it had to take the head back off cause the springs rubbed off the seals and the little springs came off some of them. (I got a full seal kit off auto vaux ) brought the head back to where I got it skimmed and tested cause they put it back together and after a day or so they said it was the wrong size seal I gave them. But they should have looked so they put new seals in no charge... Don't no if this was a cop out for them over bad work but hope this helps over the two sizes and some parts guys don't no much to much except pushing
  26. #25
    Apr 2010
    southport
    2008 civic diesel
    Quote Originally Posted by richiecs3 View Post
    There's 2 sizes in that respect buddy, with double valve spring you need ones without the lip on the outer edge, but where the valve guides are concerned there's only one, that includes the ones for double valve springs.
