f18, f20 clutches? same?
Results 1 to 7 of 7
Thread: f18, f20 clutches? same?
    Mar 2009
    essex
    astra gsi mk3
    hi does anybody know what box comes on a c18xe mk3 astra gsi? is it an f18? and does an f18 and as f20 use the same clutch?
    cheers
    Mar 2009
    essex
    astra gsi mk3
    Re: f18, f20 clutches? same?
    bump
    Apr 2007
    Hull
    Mk2 cav
    The c18xe uses the f18 with pot type flywheel where as engines i know of fitted with the f20 had the flat flywheel.So no they shouldnt be the same.
    Mar 2009
    essex
    astra gsi mk3
    Quote Originally Posted by kwkmanta View Post
    f20 can use both types, early f20 was flat and and late was pot so could be the same
    Aug 2011
    blackburn
    mk2 astra sri 1988
    yes thay will fit done on my f18 6 months ago when out put a f20 clutch in then gone four paddle now
    Mar 2009
    essex
    astra gsi mk3
    Quote Originally Posted by neilb1798 View Post
    cheers mate!
    Feb 2007
    Belfast Ireland
    cavalier sri 3.1 v6
    I'm near sure the f18 clutch a bit smaller in size.
