Mk4 Astra intercooler options
Results 1 to 5 of 5
Thread: Mk4 Astra intercooler options
    Moderator Melv's Avatar
    Dec 2006
    KEITH, N.E. SCOTLAND
    1.8 Corsa Merit + ACT
    Afternoon all,
    Being a Scotsman I'm tight with my money meaning I don't fancy forking out the £350 that TX Autosport, the laughable £611.75 that Courtney want and the ridiculous £704.68 that Regal want for a Astra G Z20LET FMIC kit.
    What options are out there?
    Is it similar to Cav / Calibra where a fronter (or similar) Intercooler will work with the right pipework? Ideally I'd like to keep the Coupe front bumper as complete and stealthy as possible.
    What home brew set up is anyone else running?
    Current Spec
    Z20LET
    Standard turbo
    GM suplied VXR plugs
    dBlias Flowmaster (being fitted soon)
    unknown dump valve.
    Thanks in advance.
    Apr 2009
    inverness
    Re: Mk4 Astra intercooler options
    with my gsi im going to be fitting a standerd EVo intercooler and weld my own pipe work at work, so it will prob cost under £200 for a good setup,
    so if you can make your own pipe work or know somone then this might be the way to go,
    sex is like math: you add the bed, subtract the clothes, divide the legs and pray you dont multiply!
    MIGClub Member crombievts's Avatar
    Jun 2007
    Dingwall
    ph1 clio 172 track wep
    i tried the evo ic on mine and it looked and fitted crap. i got a universal 1 of ebay and 1 metre of 2.5" pipe and a few bends and made my own kit. was also around £200
    Dec 2006
    Cheers gents. What's the going rate for 2nd hand kits on the forums? About £250? If so, for the sake of £50, it might save a lot of fecking about with welding, bending, joining, etc, etc.
    Apr 2009
    inverness
