clicking noise C20 xe and F20
Results 1 to 16 of 16
Thread: clicking noise C20 xe and F20
    Jan 2005
    Malta
    Corsa 2.0, Corsa 1.7
    i have a c20xe and and f20box, I replaced the 2nd gearbox but I still have the same noise, the noise is when the gear is not engaged (free) it make a clicking noise, is seems to be from gearbox but its not because i tried 2 gearboxes, when the gear is engaged it is without noise, and even when i press the clutch pedal the noise stops any idea what it can be .
    Dec 2011
    Re: clicking noise C20 xe and F20
    clutch release bearing?
    Jan 2005
    Malta
    I checked it, it was not noisy and when it is pressed the noise will stop.
    Jan 2005
    Malta
    when i press the clutch the noise stops
    West Midlands Regional Coordinator paddy>gsi/turbo's Avatar
    Nov 2004
    birmingham
    astra mk3
    clutch bearing for sure
    Jan 2005
    Malta
    i do not think its the clutch bearing because when it is pressed there is load on it and when pressed the noise will stop
    Jan 2005
    Malta
    bump
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    Some bearings go quiet under load and some get noisy and the same without load
    Sep 2008
    Auckland, New Zealan
    Chevette XE, Calibra
    What ^^^ said!
    A bit of thought could have saved you a lot of work...
    Jan 2005
    Malta
    Quote Originally Posted by Gordo View Post
    What ^^^ said!
    But the thrust bearing is not turning until the pedal is pressed so how come it can be the bearing??
    Apr 2007
    Hull
    Mk2 cav
    Thats just what they do.While its not got any pressure on it the bearings rattle around as they get loose but when you put pressure on it it squeezes the bearings together and stops the rattling.
    Mines gone to it rattles til i put my foot on the clutch then goes quiet.Soon as i lift my foot i get the rattling again.Had acouple of cars before that have done the same thing too.
    Always good practice to change the bearing when you`ve got the box off anyway.
    Dec 2006
    South Africa
    Opel Corsa B c20let
    Could be one of the pressure plate fingers is slightly bent or damaged making that noise against the realease bearing.
    1997 Corsa Lite 2l16v TS Standard 1/4 mile 13.285s @ 167.7 km/h
    2007 Nissan 1400 Champ 20LET (Conversion in Progress )
    Sep 2008
    Quote Originally Posted by smoothcorsa View Post
    Bearing is in light contact with the diaphram fingers with this design, some mechanical linkage designs have a spring pulling it from contacting the fingers, this may be what you're more familiar with.
    With hydraulic clutch systems, it's normal to have a light contact.
    Any wear or irregularities in the bearing assembly or it's retainer can result in noise.
    Not something that usually NEEDS replacement, unless it's giving a rough feel at the pedal or making a grinding or squealing noise - but it can be really annoying.
    if you pull up on the pedal, you may notice the sound going away, if it allows the release bearing to be pulled back from the pressure plate.
    Jan 2005
    Malta
    I will check it this evening and let you know thanks
    Jan 2005
    Malta
    I checked and it looks like i have a bent spring on the clutch release plate that is catching while its spinning around, now next i will remove it and see how can i fix it or else buy a new one.
    Thanks
    Jan 2005
    Malta
    HI mates from where i can buy a clutch cover (pressure plate) ????
