Power on a z20let engine
Results 1 to 10 of 10
Thread: Power on a z20let engine
    Apr 2009
    inverness
    As above really have a rebuild engine too standard spec with complete new head, pistons and bearings ect, just wondering would it handle 270 bhp without any problems? Cheers
    sex is like math: you add the bed, subtract the clothes, divide the legs and pray you dont multiply!
    Jul 2009
    Tyne & Wear
    Corsa SRI Z20LEH, B X14XE
    Re: Power on a z20let engine
    z20let should run 280bhp no problem, 300bhp on standard.......
    South East Regional Co-ordinator
    Apr 2011
    Sheerness, Kent.
    2003 Arden Zafira GSi
    198bhp from the factory....with de catted s/s exhaust, enlarged top hat, direct intake, fmic, VXR afm and injectors and an aggressive remap....275-280bhp easy �1500 will cover this....add a VXR turbo and another remap = 300bhp.
    From there you would want to look at the internals.
    Welcome to the jungle we've got fun and games.
    Apr 2009
    inverness
    Well that's the plan really already have the VXr turbo and exhaust and decats, also going to be making a hard pipe kit at work for an standard evo fmic, will also use the 1.9 cdti airbox, so just hoping for around the 270 mark with a good map, but want it too last since its a new engine, don't want to take it all back out in a years time,
    Cheers
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    With your spec its best to stick at 270 otherwise you'll be going through turbo's on a regular basis. Saying that a vxr turbo aint that expensive so i guess you could just replace it every 6 month
    "THE ROB"
    MIGClub Member crombievts's Avatar
    Jun 2007
    Dingwall
    ph1 clio 172 track wep
    mine gave up at 296 twice. broken piston. its lying out in evanton now
    Apr 2009
    inverness
    with that setup could i do the 1000 - 1500 miles run in before i get a map on it ( without doing any damage) or could i sent my ECU down to courtenay sport to get a sort of base map todo the run in then take the car down for the prober map?
    Apr 2011
    Sheerness, Kent.
    Quote Originally Posted by Rs1 View Post
    I'm on a similar spec to post 3 and my KKK turbo is still strong....seals fine on the turbo and no play on the shaft ect.
    Apr 2009
    inverness
    Quote Originally Posted by taylormade View Post
    Bump can anyone help me with this please
    Jul 2009
    Tyne & Wear
    yeah.... im running a zlet map on leh in a corsa, it hasnt been mapped yet but has covered about 8000miles with loads of mods on too...
