Astra G 1.6 8v Misfire in Cylinder 1 - Cause?
Results 1 to 7 of 7
Thread: Astra G 1.6 8v Misfire in Cylinder 1 - Cause?
    Jun 2011
    2001 Astra G 1.6 8v
    Pedal test is bringing up error 0301 which is misfire in cylinder 1.
    Have changed the coilpack and have swapped the spark plugs about and the error still persists.
    If i reset the ECU it'll stay off when driving easy, but when pushing on a bit it brings it back on.
    Any idea's what it could be?
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    Re: Astra G 1.6 8v Misfire in Cylinder 1 - Cause?
    Injector fault or is it SPi ?
    Jun 2011
    I believe its SPI
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    Looks like a carb on the manifold
    Jun 2011
    No suggestions?
    MIGWeb Moderator
    Midlands
    Nowt
    None as you have not confirmed if its MPI or SPI
    Jun 2011
    Its SPi
