Corsa c20xe problems
Results 1 to 4 of 4
Thread: Corsa c20xe problems
    Oct 2011
    conon bridge (inverness)
    nothing!
    Unhappy Corsa c20xe problems
    right here we go , recently done a conversion for a c20xe into a corsa sport , got everything gong mint and everything working , but my only problem is getting the thing to move i changed the head and gearbox at the same time , changed from an f18 to an f16 and also a new clutch , now it goes into gear no bother but it will not drive and im just a bit lost by it now been told its the shafts but have no clue what to do now , have spent a fair amount on it already and this its my 1st conversion so dont be too hard on me
    Mar 2011
    birmingham
    corsa
    Re: corsa c20xe problems :@
    Cv's actually in the hub and box properly? Does it spin the shafts?
    Dec 2006
    South Africa
    Opel Corsa B c20let
    Put it is gear and let it spin, have someone check if the inner cv is standing still or spinning on both sides.
    If the inners are not not spinning, problem is in between the flywheel and diff.
    If one inner is spinning and the shaft is not, then you have a broken inner cv.
    Process of elimination basically.
    1997 Corsa Lite 2l16v TS Standard 1/4 mile 13.285s @ 167.7 km/h
    2007 Nissan 1400 Champ 20LET (Conversion in Progress )
    Dec 2006
    South Africa
    Opel Corsa B c20let
    double post
