been offered a swap how does this sound
Fully rebuilt c20xe "redtop" engine fitted, crank was reground to 0.25 and bores honed, genuine mahle big and small end bearings, genuine mahle piston rings.
Genuine erling bottom end gaskets and seals fitted, genuine erling head gasket and seals fitted to head, valves cleaned and reseated genuine gm water pump all stretch bolts replaced with genuine gm bolts.
Gates timing belt and genuine gm roller and tensioner fitted.
Brand new LUK clutch kit fitted
dont really make that much sense to me tbh but its in a mk 3 astra
plenty folk on here that can/will help if it fails? lol
, get your astra and start a wip thread on it plenty help out there and if you do a little digging you might not need to ask as much as you would think lol
