Results 1 to 9 of 9
Thread: Piper or Cat Cams, which to break 200hp in 1.8 vaux
    Sep 2006
    POLAND
    c18xe smallblock
    hi, my engine is bored/stroked to 1.8ltr c16xe. with Mantzel, schrick 264, SuperSprint manifold it makes 176hp. which cams should be better, somebody know piper timing for over 1mm lift?
    piper 280/278
    catcams 272/272 or 282/282
    c16xe powered by corsasport.pl
    Oct 2003
    Cirencester, Glos
    GTE 16v Turbo
    Re: Piper or Cat Cams, which to break 200hp in 1.8 vaux
    You want something up in the 80's to stand a chance I'd say. Piper 285's don't quite make 200bhp on a throttle bodied 20XE.
    Oct 2002
    South London/ Surrey
    A4 sport avant Clio172
    What lift on these cams? I know Cat like high lift lower duration.
    www.shonkyopels.de
    Sep 2006
    POLAND
    c18xe smallblock
    cat 272/272 over 1mm duration is 235/235 with 8.9/8.9mm lift and 1.95/2.0mm at tdc
    cat 282/282 over 1mm duration is 249/249 with 10/10mm lift and 3.45/3.7mm at tdc
    piper 280/278 11.43/11mm lift and 2.74/2.49 at tdc
    however i know, it's quite sure info that over 1mm lift at piper is no more than 210degree... so they arent so long like they seems to be
    Oct 2002
    piper give 'fake' measurements. Out of them cams I would be going for the cats if the quest was 200bhp, on my XE I had 300 degree ones, they had 12.7mm lift
    I just noticed the engine is an x16xe thats been bored rather than an x18xe1. What sort of headwork have you had done?
    www.shonkyopels.de
    Sep 2006
    POLAND
    c18xe smallblock
    headwork includes polished channels, removed air channel from exhaust channel, 3 angle valves. valves are sts c16xe valves
    Oct 2002
    What is the cars main use? Road or track work?
    www.shonkyopels.de
    Sep 2006
    POLAND
    c18xe smallblock
    toy for a weekend, hardly ever as daily car
    Sep 2008
    Auckland, New Zealan
    Chevette XE, Calibra
    I'd be looking at a carb or throttle body conversion first, TBH.
    The other issue is valve to piston clearance - this may not be a problem, though, if you're using higher compression pistons that already have deeper valve notchets.
    If it is a problem,ei, using a stock type piston, you may be restricted on how much furhter you can go without having them cut.
