C20LET Corsa oil pressure
Results 1 to 6 of 6
Thread: C20LET Corsa oil pressure
    Jan 2012
    when i first start the car im getting 30psi oil pressure? thats if i rev it up a bit, on idle i get 20?
    and ideas? its a frash fitted sender/ gauge, what im wondering is if there is a certain size wire i must use for the sender?
    cheers
    james
    Oct 2005
    East Midlands
    Nova 20XE
    Re: oil pressure
    What car and engine? Also what sender and gauge, Vauxhall or aftermarket?
    Nov 2005
    chester/n.wales
    evo 6 gsr
    Re: oil pressure
    what are you getting when its hot? say 25min after runiing or of driving? idel shold be about 22psi, then they say its about 10psi for every 1000revs up, seems low from cold though, id be expecting 60-70psi when stone cold
    phil nichols - Engine building and Cylinder head work. stock - performance. - can now supply gaskets, water pumps, cambelt kits, oil pumps, uprated bearings, bolts, rings, pistons. PM FOR INFO
    Jan 2012
    Re: oil pressure
    well it is stone cold, its a c20let in a corsa. basically it started to sound tappetty so i fitted an aftermarket gauge and sender brand new,
    i have oil at the top. but yeah goes to 30 and does sound tappetty
    im too worried to drive it too get it warm, the oil pressure isnt under load, just in neutral sitting there
    Feb 2011
    Maltese Islands
    rebuilt c20let
    Re: C20LET Corsa oil pressure
    mine starts at 75psi and goes higher with acceleration. only when the oil has warmed up it should read about 30psi on idling. is the oil icon lit on the dashboard? also check the gauge is connected correctly or if possible use another gauge to compare results.
    matt
    When It comes to motorsport its what you build not what you buy
    Jan 2012
    sorted the oil pressure problem, i took the sump off to see that the oil pickup bolts had worked loose, simply loctited them back in and oil pressure shot straight up to what it should be
    thanks for the help
