Refitting cambelt after it's snapped...... Finding TDC
Results 1 to 23 of 23
Thread: Refitting cambelt after it's snapped...... Finding TDC
    Aug 2008
    Barnsley
    I need to know where TDC is for cylinder one.
    Sounds easy, but it turns over 720*, so it has 2 TDC marks.
    As the belt snapped, I am not relying that the closest TDC is the correct one.
    How do I line it up all correctly?
    Aug 2010
    Amsterdam
    5-door Astra MK2 C20XE
    Re: Refitting cambelt after it's snapped...... Finding TDC
    If it helps....
    Aug 2005
    essex
    I dont understand why you need to worry about 720'. Align the marks, turn the crank through at least 720' by hand, I usually do 1440 (4 crank revs). check they all align.
    MIGWeb Moderator
    Midlands
    Nowt
    X16xe?
    I'm lost to your comments. How can it have two TDC marks?
    Jul 2004
    Southampton
    GTE 16v / Saab 2.0t
    Please clarify what engine you have.
    Aug 2010
    Amsterdam
    LOL, I reckoned he was on about his X16XE engine, hence the handle... but you never know....
    MIGClub Member jamied's Avatar
    May 2003
    northampton
    loads of things
    looking at what is put in the first post and thinking in a non-technical term, the TWO TDC marks are only ONE.....
    as in he has all the marks lined up, Crank & Cams..
    Turns the crank one turn (360) to the TDC mark and the cams don't line up..
    Turns crank again (360+360=720) to the TDC mark and cams line up....hence him thinking two lots of TDC going by the crank marking.
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    lol, not this again, did no one read the turbo stevo incident thread? it is impossible to get TDC wrong on a twin cam if you align the marks, the crank cannot be 360 degrees out!!
    SHoNkyOpELs.de
    Jun 2002
    Wrectum
    Shuvit, e36 track car
    Oh christ.
    Jun 2002
    Wrectum
    Small point, but if you're just putting a cambelt on after one's snapped you're pissing in the wind really as it will be fubar.
    Aug 2010
    Amsterdam
    This is indeed an interference engine isn't it??
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    yep
    SHoNkyOpELs.de
    Aug 2005
    essex
    oh dear....the lack of reply speaks volumes
    Aug 2008
    Barnsley
    The lack of reply is due to me being out cleaning the sump at my mates garage.
    Oh and it's an X20XEV engine. I forgot to put that bit. My bad.!
    4 valves were bent and had two valve guides fixed and had the head acid dipped. I didn't bother putting that bit in as it didn.t reallt matter.
    So it doesn't matter were the crank is at aslong as it lines up to the marks?
    I did mean, one full turn of the crank means half a turn of the cams. So can the crank ever be out or does it not matter? I'm just wondering on all the damn sensors on the engine.
    Oh and no, i've not fitted the belt just yet as didn't want to get it wrong and have to take it off again.
    Aug 2008
    Barnsley
    Oh and Vinci, many thanks. I've found something like that but yours has got more detail in it.
    Jun 2002
    Wrectum
    Set crank to mark and cams to marks, everything will go swimmingly
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    yeah, there will be a point once the belt is on where the cams will be 180 out and the crank on its mark, but this is normal, as tathan reiterated, if you align the crank and cams up and fit the belt, all will be well
    SHoNkyOpELs.de
    Aug 2008
    Barnsley
    HT lead order? Is this an inside joke that I don't know about?
    I left mine all connected to the coil pack so there can't be any mix-up.
    Aug 2008
    Barnsley
    Already had it off, stripped it down (4 valves bent and 2 valve guides). I've even removed the sump and given it a clean out whilst i'm working on it.
    Now i'm putting it all back together I just wanted to make sure that the belt can't be fitted wrong if it's all marked up.
    MSG
    MSG is offline
    MIGClub Member MSG's Avatar
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    Quote Originally Posted by Steve X16XE View Post
    Its an X20XEV
    it is reccomended that on this engine you do not rely on the crankshaft pulley mark for timing purposes as the outer part of the pulley can slip as the pulley is rubber damped which means it is made of two seperate parts put together with a rubber stuffed between the two parts, and the outer part can often spin from the other part that is bolted to the carnk flange, so the timing mark can drift and you end up getting it timed wrong, and risk valves being bent.
    Therefore it is best to not rely on the pulley mark but use the dot on the crank flange. So unbolt the 4 screws and remove the main pulley then use the timing mark (a dot) on the crankshaft flange, the dot should be pointing downwards or at 6' O clock position whilst the two camshaft marks should corresponds to the marks on rear cover of the timing belt. Just to confirm, when the dot on the crank flange is at 6' O clock position (bottom most) the pistons 1 & 4 should be at the top most
    position (tdc) . (you can use molgrips to hold the two cam wheels together e.g. the left wheel grip at 3'O clok and the right wheel gripped at 9'Oclock to lock them from turning whilst fitting the belt.
    Dec 2007
    Nuneaton
    A carbed xe'd reno kangoo
    Stick a screwdriver down cylinder 1 and turn crank until it reaches its highest point, find it, go clock wise and anti clock wise until highest point is exact thus being the TDC.
    Vectra B Estate 2.2
    Vectra B Saloon 2.6
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    This is the exact way it's done on the X20XEV mate
    Late Type C20LET Engine Timing
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    And here's a tip to lock cams to fit belts if you don't have the locking tool, cut 2 small pieces of p1200 wet & dry and remove the 2nd cap on each cam then put the paper in facing down then refit the caps and tighten down, this will hold the cams solid enough to fit the belt, remember to remove paper before turning over the engine or it will end in tears, this is a tried and tested method and works perfectly
