1995 Corsa with C20LET:
As the title suggests, the red/blue live feed to the fuel pump is getting hot just around the first few inches by the fuel pump relay. So hot it made the blue insulation on a crimp-on connector shrink around the spade connection to the point it pierced through.
The corsa red/blue fuel pump wire is only 1.5mm so I'm going to try replacing the whole length with a larger gauge wire. I would have thought the original wire should have been up to the job though? I'm using a new walbro pump and the pressure is good on my afpr.
Has anyone else had this problem, and would this be a likely cause of an rpm specific misfire?
